Scott Conger's Float-Valve
Jugster
First Name: Bob
Last Name: Coiro
Board Member Since: 2009
Post by Jugster » Thu Oct 26, 2023 9:40 pm
I recently installed one of Scott Conger's enlarged aperture float-valves in my NH carburetor and I'm just delighted at the far more authoritative way my car goes uphill. The difference is quite noticeable.
jsaylor
Last Name: Saylor
Re: Scott Conger's Float-Valve
Post by jsaylor » Fri Oct 27, 2023 12:21 pm
Yes. Have one in my 21 Touring and I experienced the same thing. My son drove my it, not knowing about the valve, on a tour and noticed the difference on long hills right away.
Tmooreheadf
Last Name: Moorehead
* REQUIRED* Type and Year of Model Ts owned: 24 Touring, 25 Coupe,
Post by Tmooreheadf » Fri Oct 27, 2023 9:08 pm
I have one of Scott’s big valves on one of our cars. I was talking to someone about it and how well it worked on hills, etc. This fellow said I don’t want one because I’ll burn more gas. I just really didn’t know how to respond to that comment!
First Name: john
Last Name: karvaly
Post by speedytinc » Fri Oct 27, 2023 9:12 pm
You cant fix S.....
Arbs
Last Name: A
Board Member Since: 2022
Post by Arbs » Fri Oct 27, 2023 9:27 pm
Scott hasn't been on the forum in a bit but I would love one of these float valves. If someone could get me in touch with him, I'd appreciate it.
Last Name: Juhl
Post by Oldav8tor » Fri Oct 27, 2023 9:29 pm
I checked my mileage before and after installing the valve. NO change! Just better performance.
Last Name: Wrenn
Post by TWrenn » Fri Oct 27, 2023 10:01 pm
Do the member search at the top of this page where the 3 little lines are and PM or email him.
RVA23T
Last Name: C
Post by RVA23T » Fri Oct 27, 2023 10:08 pm
You cant fix S.....
The problem is S..... is both abundant and FREE!
Before I upgraded to my Stromburg OF I added Scott's full flow to my NH and enjoyed the improved hill climbing near of former house. 3 or 4 mhp at the tip of the hill! Never noticed lower gas milage from it.
Everything works in theory.
Reality is how you determine if something works or not.
Arbs
Last Name: A
Post by Arbs » Fri Oct 27, 2023 11:42 pm
I'll try again. Left him a message both ways about a month ago. He seems to have left the forum.
Post by TXGOAT2 » Sat Oct 28, 2023 6:44 am
Using the improved valve assembly will NOT adversely affect fuel mileage. It could improve gas mileage under some circumstances by allowing a car to climb a steeper hill in high rather than low.
Last Name: Hatch
Post by Dan Hatch » Sat Oct 28, 2023 3:46 pm
Scott is still making the valves. Contact him by email.
NOT BY PM, LIKE MANY OF US PMs DON’T WORK.[/b]
Just give him time to answer. Dan
Post by Original Smith » Wed Nov 01, 2023 12:15 pm
Too bad he doesn't sell to California residents! I've tried to order one several times. He won't even bother to answer my emails!
Steve1920
First Name: Steven
Last Name: Grant
* REQUIRED* Type and Year of Model Ts owned: 1920 Open Express, 1922 Centerdoor, 1924 Coupe
Post by Steve1920 » Wed Nov 01, 2023 12:51 pm
No California sales? Is that because of the vehicle emission standards there? Would they apply to a vehicle that old- one that did not have any emission equipment to start with?
Not looking to debate the issue, just curious about the rules and how they apply to old car parts.
Thanks.
Steve
Jim11787
First Name: Jim
Last Name: Sarc
Board Member Since: 2023
Post by Jim11787 » Wed Nov 01, 2023 12:54 pm
Isn’t the seat made of lead? Possibly why sales prohibited in California?
First Name: john
Last Name: karvaly
Post by speedytinc » Wed Nov 01, 2023 12:58 pm
Seal is laed. So what? I buy my own lead sheet to make these seals. Lead has not been outlawed YET.
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Wed Nov 01, 2023 1:08 pm
John Saylor is in California and he got one somehow.......................
jsaylor
Last Name: Saylor
Post by jsaylor » Wed Nov 01, 2023 4:25 pm
I bought mine several years ago - February 2019. No restriction to California at that time. Maybe it's a sales tax issue now.
Last Name: Juhl
Post by Oldav8tor » Wed Nov 01, 2023 5:35 pm
I think Scott is taking a little breather from the forum and from some of his Model T activities....too much unnecessary drama on the part of some folks. I find that too bad because Scott has always been a source of sound advice. I understand the valves will be available for the foreseeable future but I cannot tell you why they can't be sold in California.
skyhunter
First Name: Donncha
Last Name: OapostropheMurchu
* REQUIRED* Type and Year of Model Ts owned: 1916 Speedster
Post by skyhunter » Mon Dec 18, 2023 9:48 pm
Does he have a website?
RVA23T
Last Name: C
Post by RVA23T » Tue Dec 19, 2023 6:02 am
Sent you both PM and email through the forum with Scott's info
Rjackson
First Name: Ron
Last Name: Jackson
* REQUIRED* Type and Year of Model Ts owned: 1915 roadster 1925 coupe 1923 Tudor 1927 speedster
Board Member Since: 2014
Post by Rjackson » Tue Dec 19, 2023 10:45 am
I would like to know where to buy the float valves.
I am in Colorado and we have some hills. Need try it out on the top.
Thanks Ron
JohnM
Last Name: Michaelree
Board Member Since: 2010
Post by JohnM » Tue Dec 19, 2023 11:02 am
On this forum board index, scroll down to services. Go there and scroll down to "Full Flow Float Valves", click his name and there's a link to his email.
Post by Norman Kling » Tue Dec 19, 2023 12:25 pm
There should be no change in fuel mileage because whenever the float bowl is full the mixture will be the same as it is controlled by the mixture needle. Only time it might change is when the float level drops because it is not being replenished by the small valve. At that time the mixture will be lean or the engine will stop. Anyway, the fuel mileage is dependent on how many steep hills you climb and how fast you accelerate. So if you go easy on the throttle it should be the same and maybe even better because you will be able to drive in high gear more of the time.
