Scott Conger's Float-Valve
Jugster
Topic author - Posts: 182
- First Name: Bob
- Last Name: Coiro
- Board Member Since: 2009
I recently installed one of Scott Conger's enlarged aperture float-valves in my NH carburetor and I'm just delighted at the far more authoritative way my car goes uphill. The difference is quite noticeable.
jsaylor
- Last Name: Saylor
Re: Scott Conger's Float-Valve
Yes. Have one in my 21 Touring and I experienced the same thing. My son drove my it, not knowing about the valve, on a tour and noticed the difference on long hills right away.
Tmooreheadf
- First Name: Tom
- Last Name: Moorehead
I have one of Scott’s big valves on one of our cars. I was talking to someone about it and how well it worked on hills, etc. This fellow said I don’t want one because I’ll burn more gas. I just really didn’t know how to respond to that comment!
You cant fix S.....Tmooreheadf wrote: ↑Fri Oct 27, 2023 9:08 pmI have one of Scott’s big valves on one of our cars. I was talking to someone about it and how well it worked on hills, etc. This fellow said I don’t want one because I’ll burn more gas. I just really didn’t know how to respond to that comment!
Arbs
- Last Name: A
- Board Member Since: 2022
Scott hasn't been on the forum in a bit but I would love one of these float valves. If someone could get me in touch with him, I'd appreciate it.
- Last Name: Juhl
I checked my mileage before and after installing the valve. NO change! Just better performance.
RVA23T
- Last Name: C
The problem is S..... is both abundant and FREE!speedytinc wrote: ↑Fri Oct 27, 2023 9:12 pmYou cant fix S.....Tmooreheadf wrote: ↑Fri Oct 27, 2023 9:08 pmI have one of Scott’s big valves on one of our cars. I was talking to someone about it and how well it worked on hills, etc. This fellow said I don’t want one because I’ll burn more gas. I just really didn’t know how to respond to that comment!
Before I upgraded to my Stromburg OF I added Scott's full flow to my NH and enjoyed the improved hill climbing near of former house. 3 or 4 mhp at the tip of the hill! Never noticed lower gas milage from it.
Arbs
- Last Name: A
I'll try again. Left him a message both ways about a month ago. He seems to have left the forum.
Using the improved valve assembly will NOT adversely affect fuel mileage. It could improve gas mileage under some circumstances by allowing a car to climb a steeper hill in high rather than low.
- Last Name: Hatch
Scott is still making the valves. Contact him by email.
NOT BY PM, LIKE MANY OF US PMs DON’T WORK.[/b]
Just give him time to answer. Dan
Too bad he doesn't sell to California residents! I've tried to order one several times. He won't even bother to answer my emails!
Steve1920
- First Name: Steven
- Last Name: Grant
- * REQUIRED* Type and Year of Model Ts owned: 1920 Open Express, 1922 Centerdoor, 1924 Coupe
No California sales? Is that because of the vehicle emission standards there? Would they apply to a vehicle that old- one that did not have any emission equipment to start with?
Not looking to debate the issue, just curious about the rules and how they apply to old car parts.
Thanks.
Steve
Thanks.
Steve
Jim11787
- First Name: Jim
- Last Name: Sarc
- * REQUIRED* Type and Year of Model Ts owned: 1926 Roadster Pickup
- Board Member Since: 2023
Isn’t the seat made of lead? Possibly why sales prohibited in California?
Dan McEachern
- First Name: DAN
- Last Name: MCEACHERN
John Saylor is in California and he got one somehow.......................
jsaylor
- Last Name: Saylor
I bought mine several years ago - February 2019. No restriction to California at that time. Maybe it's a sales tax issue now.
- Last Name: Juhl
I think Scott is taking a little breather from the forum and from some of his Model T activities....too much unnecessary drama on the part of some folks. I find that too bad because Scott has always been a source of sound advice. I understand the valves will be available for the foreseeable future but I cannot tell you why they can't be sold in California.
skyhunter
- First Name: Donncha
- Last Name: OapostropheMurchu
- * REQUIRED* Type and Year of Model Ts owned: 1916 Speedster
Does he have a website?
RVA23T
- Last Name: C
Sent you both PM and email through the forum with Scott's info
Rjackson
- First Name: Ron
- Last Name: Jackson
- * REQUIRED* Type and Year of Model Ts owned: 1915 roadster 1925 coupe 1923 Tudor 1927 speedster
- Board Member Since: 2014
I would like to know where to buy the float valves.
I am in Colorado and we have some hills. Need try it out on the top.
Thanks Ron
Thanks Ron
JohnM
- Last Name: Michaelree
- Board Member Since: 2010
On this forum board index, scroll down to services. Go there and scroll down to "Full Flow Float Valves", click his name and there's a link to his email.
There should be no change in fuel mileage because whenever the float bowl is full the mixture will be the same as it is controlled by the mixture needle. Only time it might change is when the float level drops because it is not being replenished by the small valve. At that time the mixture will be lean or the engine will stop. Anyway, the fuel mileage is dependent on how many steep hills you climb and how fast you accelerate. So if you go easy on the throttle it should be the same and maybe even better because you will be able to drive in high gear more of the time.
