ruckstell adjustment
mike37 cdn
First Name: mike
Last Name: mclean
Post by mike37 cdn » Fri Nov 10, 2023 9:58 pm
hi all I am working on a 22 centerdoor with a Ruckstell rear end I had a leak were the shift lever housing bolts on it has two 7/16 fine thread bolts on one side of the housing and one on other side is a 7/16 bolt and a 9/16's head with a lock nut below it and a point on it it to go into something inside any body know what the adjustment should be for this bolt thanks mike
Re: ruckstell adjustment
Post by RajoRacer » Fri Nov 10, 2023 10:23 pm
That bolt tightens down into the notch plate - one of two - snug it up good then tighten the jam nut.
Craig Leach
First Name: craig
Last Name: leach
Post by Craig Leach » Mon Nov 20, 2023 12:17 pm
Hi Mike,
I found that the gasket did not mate the flange completely. I had to remove the shifter & make a gasket that fit better.
Craig.
