Camshaft flange detail
Rajo T Speedster
Topic author - Posts: 14
- Last Name: Rowe
- * REQUIRED* Type and Year of Model Ts owned: 1918 RHD Speedster
Does anyone know if the flange near the front of a T cam is part of the cam machining or is it shrunk on?
Still trying to find a suitable cam for a Rajo OHV head engine.
John
Rajo T Speedster
Western Australia
John
Rajo T Speedster
Western Australia
OlGeezer
- First Name: Andrew
- Last Name: Turner
- * REQUIRED* Type and Year of Model Ts owned: 1922 Runabout
Re: Camshaft flange detail
I'm no expert, but from my experience, the flange near the front of a T cam is usually machined as part of the camshaft. I haven't heard of it being shrunk on separately.
I am certain that the flange is integral to the shaft and not an add-on piece.
- First Name: craig
- Last Name: leach
Hi John,
If my memory serves me correctly the Rajo rocker arms are a1:2 ratio this will give you almost a 1/2" lift with a stock cam. If valve timing
is what you are looking to change I think Dan McEachern makes a timing gear set for that reason.
I installed a Chaffin's "modified" reground camshaft in my BB RAJO near 30 years ago now - it performs quite well !
Dan McEachern
- First Name: DAN
- Last Name: MCEACHERN
Many commercial Rajo heads used 1:1 rocker arms, so be aware.
kmatt2
- Last Name: Matthiesen
John, If you are going to run a reground Model T cam you will need to use a late 1924-27 T cam , the cam with the long front lobe. The earlier T cams use a shorter front lobe and a longer front bearing to take up thrust , but require modified front thrust when regrinding because the long front bearing won’t limit thrust on reground cam due to the cut down cam heal .
- First Name: craig
- Last Name: leach
Hi Dan,
That is what I love about the Forum I get to learn something new every day.
John,
Kevin is correct about the early year regrind cams but if you have a Bosch timing cover distributer there is a thrust
adjusting screw in the cover for that. & the thrust washer kit is not expensive or hard to install most of the time.
John,
