Air pressure for a 32 x 4.5 TT tire?
TheSaintDiscJockey
First Name: Brooks
Last Name: Schlieben
* REQUIRED* Type and Year of Model Ts owned: 1923 TT
Post by TheSaintDiscJockey » Mon Nov 13, 2023 9:34 am
Looking for the proper air pressure for the above tire?
These are old Seiberling tires.
Due for replacement.
Many thanks!
Cordes_jeff
First Name: jeff
Last Name: cordes
* REQUIRED* Type and Year of Model Ts owned: 25
Re: Air pressure for a 32 x 4.5 TT tire?
Post by Cordes_jeff » Mon Nov 13, 2023 9:53 am
I air my Chippewa tires to 60, they are 32x4.5 WW2 era tires.
Last Name: Wrenn
Post by TWrenn » Mon Nov 13, 2023 10:21 am
Many thanks!
Those were darned good tires back in their hey-day. They were literally the most round, well balanced tire on the market, they seldom needed the balance weights so commonly used. If I recall correctly they had a distinct look to them also...with what I'd call a small "lip" extending outward from where the sidewall met the tread. Dad had a set on his '65 Buick Wildcat and they sure rolled smooth. This was just before he then went to radials when they hit the market.
Post by RajoRacer » Mon Nov 13, 2023 10:23 am
I run 45 - 50 lbs. - TT's ride so rough anyway !
