Different T Things
				Nathan Pederson
- First Name: Nathan
- Last Name: Pederson
Different T Things
Hello fellow T'ers,
Will be posting some miscellaneous T pictures. Start with this one:
				MichaelPawelek
- First Name: Michael
- Last Name: Pawelek
Re: Different T Things
A tiny squirt of grease should quiet things a bit….
You need a super thick grease to run this one.
Can only imagine the noise and vibration that thing made!  Yet,  no doubt it still made the car move!
NO problem, just pack it with sawdust and grease and drive straight to the used car lot and sell it!
				tiredfarmer
- First Name: leonard
- Last Name: simunek
How about using JB Weld, that should fix it.
				halftracknut
- First Name: randy
- Last Name: lee
- * REQUIRED* Type and Year of Model Ts owned: 1926 pickup
turn that baby down and put a ball bearing on it?
				Kerry
- Last Name: van Ekeren
Back in the day, you could buy the uni in pieces, ie, male and female knuckles, pin, and rings x 2. it makes you wonder why, what would be salvageable from a stuffed uni that could be repaired by just buying one piece.
				Nathan Pederson
If I ever need a U joint, hopefully I can find a better one.
				Nathan Pederson
Old time repair:
				MichaelPawelek
Necessity is the Mother of Invention!
				Dropacent
- Last Name: Morsher
Keep’em coming.  Love it!
				Rich Bingham
- First Name: Rich
- Last Name: Bingham
"Get a horse !"
				Nathan Pederson
Surprisingly, the switch still works, and I wood not hesitate to use it.
				Les Schubert
- First Name: Les
- Last Name: Schubert
Funny thing about the U joint is that I have fixed quite successfully and used ones that looked almost that bad. The reality is that the “ring parts” actually sustain very little wear and the end pieces are not difficult to fix!!
				Nathan Pederson
Carb inlet casting crack fixed with brazed on steel collar.
Blackie (also known as "Henry Furred")
Flat 8
Flat 8
- First Name: craig
- Last Name: leach
Mother of invention? I worked for a guy who's moto was " Creating necessity by being the mother of invention" I'll bet he pays more in taxes than I make.
Craig
						Craig
				Nathan Pederson
Thanks for the comments, and also the good humor too!
Three on the tree
My not too fancy but works good HCCT
						Three on the tree
				Moxie26
- Last Name: Jablonski
Apply a little steel wool to the inside of that brake drum and also the pointer and you'll have a terrific spark on your test hcct.   .. ..
				Nathan Pederson
Good advice there, it does need some shining up.
I find that it's fun to fix up coils and get them back within specs.
"E" crankshaft?
				Nathan Pederson
Crank shows faint AA.
Both crank and block are cracked. Good for HCCT use, though.
				Nathan Pederson
Here's what a radiator shell looks like with a runningboard script welded in:
Modifications made on '26 coupe to windshield height and header.
1243 Model T type engine from 1930's auto shop class.
				Bryant
- First Name: Bryant
- Last Name: Shafer
keep them coming I miss it
				Nathan Pederson
Used this setup many years ago to bore a rebabbited connecting rod to an odd size.
Rod was clamped to the vertical bolt.
Coil once owned by Orville K Wright
Rear brake drum speedometer drive. Spring loaded and pivots on brake shoe bolt.
				Nathan Pederson
TT with the gas tank moved over to allow room under the seat for a battery.
Made a different coil box switch key to replace the lever key that gets kicked to off
sometimes when using brake.
Working on the coupe in 1976.
Where does time go?
Where does time go?
				Nathan Pederson
A few wrong T things:
These brake drum lugs are the wrong kind of 'groovy'.
If you have run across 30x31/2 rims with the valve stem hole in the wrong place,
they could have been from 1924 Chev wheels like these.
Here's a story told by an old time mechanic from back in the day:
If you wanted to rile up a Ford owner about his Model T, you would tell him
the throttle rod was the only thing keeping the motor from falling out...
And these two pictures are...just plain wrong:
Re: TT gas tank/battery pic: A nice mix of gasoline vapor and hydrogen could give you a real kick in the pants...
				Nathan Pederson
TXGOAT2, Thanks for the observation and heads up.
Things are wide open under the gas tank, what are the chances???
					Last edited by Nathan Pederson on Thu Jan 20, 2022 8:01 pm, edited 1 time in total.
- First Name: Adrian
- Last Name: Whiteman
Brake shoe repair found in my TT:
And an idler wheel for use in 'some' machine or another:
				Nathan Pederson
How many Model T's have been fixed over the years with just baling wire and pliers,
and then, how about all the handy parts left when they were dismantled!
Quite a few Fords around here were made into wagons. This was my Grandpa's.
He said it was a touring car, then made into a frame car with a homemade body in the 1920's,
and was turned into a wagon in the 1930's. Still in use years later.
I have a set of those demountable disc wheels on my Racer - near as I could establish, they were manufactured by a Motor Utilities Co. who also produced bolt-on "salesman" bodies for runabouts.
				Nathan Pederson
I looked for info on the 30x31/2 disc wheels and could only find that Chev offered them
as an option on 1924 closed cars. Motor Utilities Co. must have been making them for Chev?
Great wheels to have on your Racer!
These Chevy disc wheels were at Moultrie GA swap meet in Nov.    Decent set of wheels,  no seller info..
									The best way is always the simplest. The attics of the world are cluttered up with complicated failures.     Henry Ford
				Nathan Pederson
A side by side 8 cylinder chassis looks to be easily buildable (although something like this might be
best left on paper). Just bolt frames together, cut and weld the front axles, and connect the
brake lever cross shafts. Head scratching part would be how to do the rear axle. Simplest way might
be to have each engine drive only one wheel. Add auxiliary brakes. Link up the timer and
throttle rods and you're ready to go a-T-ing!
To operate, use only the driver's side pedals for low, reverse, and brake. The passenger side engine
would remain in neutral until the hand brake lever is moved forward into high gear, and at that
point both engines power the car.
  Just bolt frames together, cut and weld the front axles, and connect the brake lever cross shafts. Head scratching part would be how to do the rear axle. Simplest way might
				Nathan Pederson
Side By Side 8 Cylinder 8 Passenger Ford Touring Car
That's a good one Nathan. I see that it narrows significantly towards the front. The left drive shaft doubles as a radius rod and it also has twin batteries.
Kalamity Dick sold his for $75 back in 1944.
				Nathan Pederson
Kalamity Dick=
				Nathan Pederson
1919 Ford 8
				Bryant
- Last Name: Shafer
I love it! Room for the whole family
				Nathan Pederson
Great painting there, Rich. Always fun to see it!
The Ford 'narrow track' could go on even the narrowest mountain roads.
They were, however, a bit tippy.
Culture in the country.
Dash light cover really sparkles.
Have a great Model T day everyone!
				Nathan Pederson
Early SUV?
Tread comparison
Long ago blacksmith made this handy T hitch.
I always look forward to 'working' in the garage. Bet you do, too.
The red car has a shortened frame of 10". The reason was I thought it made the proportions better.
Grandpa's old work bench from the 1920's is still in the machine shed and is well preserved with
soaked in motor oil. Some of that oil is from Ford repairing back in the day. With the Model T era tools
on there, it could just as well be 1925.
						Tread comparison
				Nathan Pederson
The Ford TTTT Tuton Truck. Built for the man who wants extra hauling capacity and a roomier CC Cab.
Have you driven a Ford lately?
Are these still available?
I once used a Champion spark plug to plug a pipe fitting in my home gas line.
				Nathan Pederson
Hey Mark, we think alike!
And Frank, the availability of the 'Funny Projects' u-joint kit seems to be limited at this time.
				Nathan Pederson
those spring things inside the headlight rim can be difficult to install and i didnt have one anyway
so i used an upholstery spring works great note also the ground wire added from the bucket to the socket and also the use of jbweld
and then there was light
The "Warm Glow,
it's beautiful beyond imagination
illuminating, radiating, pulsating
ready to merge with many souls awaiting
the ultimate infusion
force of life enlivening empty shells
emitting bolts of love and healing
to the depths of hell
evaporating the contamination
from the wishing well..."
Casey Ligon
Well Heck, maybe it isn't all that romantic but you have to like it.
Casey Ligon
				Nathan Pederson
To experience light is truly a wondrous thing...
especially since I added that ground wire inside the bucket.
Thanks for posting the poem Rich, someone like me needs all the culture he can get!
				Nathan Pederson
A few years ago I started hoarding Model T jacks. They are all over around here and easy to find.
9 jacks so far and the goal is to eventually collect 25 of them.
Don't they always say a person should have goals in life?
They are nice to have around and cheaper than axle stands.
				Nathan Pederson
Yes, they are indeed real useful as jack stands.
Update: Slightly disappointing swap meet season for jacks in 2022, as only three were found.
(However, one was for a TT)
I think this is a meme whatever that is.
					Last edited by Nathan Pederson on Wed Dec 28, 2022 10:08 pm, edited 1 time in total.
a humorous image, video, piece of text, etc., that is copied (often with slight variations) and spread rapidly by Internet users
				Nathan Pederson
Steve that's a good one
90+ years ago the old Ford may have traveled on many a road such as this, but not anymore.
Nowadays, the coupe's present owner completely babies it!
				Nathan Pederson
A yardstick is often useful for measuring.
Picture for fun a cylinder head cast out of gold instead of cast iron.
It weighs about 100 lbs. and is worth approximately 2.3 million.
Simmons carb and the story is that it was once fitted to a 1920's John Deere hit and miss engine.
(I bet it still missed lol)
Features an inventive way to fix the choke return.
				Nathan Pederson
Purchased with the wire already attached, this NH carb was bought at the swap meet for a dollar.
You probably won't find a worse one, but long ago someone rescued it anyway.
Makes for interesting wall art out in the barn.
Jig for regluing coil joints clamps from all sides.
Coil Box
Coil Box
				browning
- Last Name: Kahle
- * REQUIRED* Type and Year of Model Ts owned: '26 coupe, '26 touring, ‘14 Staude tractor conversion, '27 coupe, '19 roadster, ’15 speedster, '14 touring
I wonder how fast a thirty cylinder Model T would go?
Carb inlet casting crack...
Very common, from over-tightening the fitting. I have several carb bodies with that damage.
				Nathan Pederson
Good point there, Steve.Steve Jelf wrote: ↑Wed Dec 28, 2022 11:53 amCarb inlet casting crack...
From my experience, sometimes a 1/8-27 NPT pipe tap is useful to just 'slightly' enlarge the threads in the inlet,
and that helps to get the elbow in the correct position and avoids cracking the casting.
I've always had good luck using Permatex #2 Non Hardening Form-A-Gasket on the threads.
				Nathan Pederson
No doubt it would have a loooooooong hood!
This coil set was pulled years ago from the same coil box and all four have survived in good original
and working condition. What I find interesting is that three of the four are perfect matches and it's
likely that those have been together since leaving the factory.
In the old days, if someone did not have the right size wrench, they at least had an 11/16th
hammer and chisel.
				Nathan Pederson
A photoshopped image may or may not be such a good thing.
Gravel Road Limo
						Gravel Road Limo
The Gravel Road Limo looks great and would be buildable.
Duey_C
- First Name: Duane
- Last Name: Cooley
Hope this OK Nate! A little cracked like the chair.
A steering device for the ones not knowing if they're coming or going. Not as twisted tho...
Stopped at Bob's near Milan some years ago, headed north on 17 or 29 and stopped in. The fella gave this to me. I did buy an OT engine from him tho.
				Nathan Pederson
Hello Duey, that is definitely a different Model T thing, fits in just right on this thread.
				Nathan Pederson
Building a Fordor Coupe using Paint 3D:
My '26 Coupe.
The build in progress.
Could use a little more work here and there, but turned out ok.
						My '26 Coupe.
				Nathan Pederson
Got new shoes on the TT.
Been thinking about making a Model T trailer to go with the chariot.
Computer generated image shows how it might look.
Ford Taxi
Ford Taxi
				Nathan Pederson
Arbs, I'm thinking it's still going to be  dripping oil for awhile yet...
				Nathan Pederson
My TT needed doors.
				Nathan Pederson
"Hub Clamp" Model T Wood Wheel Puller
Here is a clamp I have designed for pulling rear wood wheels.
It is made of steel and has 2 1/8 X 24 threads to match the hub threads.
The clamp is not screwed on. Instead, the halves are placed onto the hub
and are tightened down with 1/2" fine thread allen bolts.
For now I have a 3 jaw puller that works with it.
A future upgrade may be to add a built in puller bolt to the clamp.
Thats a fine idea.
Better than a stock, screw on type puller if the threads a a bit worn.
Consider selling some?
				Nathan Pederson
Speedytinc,
I would have a clamp available for someone to help evaluate the fit on different
hubs and the overall usefulness.
There is only a 5/8" space between the back of the clamp and the hub flange, so
not all puller jaw ends will work with it. A robust puller with compact jaw ends is needed.
I am looking at ways to incorporate a puller bolt or bolts into the design to make
a self contained unit.
The goal is a tool that will pull even the real stuck hubs.
I see the beauty in the simplicity & economy of manufacture. 5/8 is plenty of room for more period correct pullers. Thinking Proto bar type.
I could see an encapsulating housing such as a KRW type pinion puller. But that would make mfg/time cost rise exponentially.
				Nathan Pederson
Proto Bar puller looks like a good way to go with this.
Thanks for the comments!
Duey_C
- First Name: Duane
- Last Name: Cooley
Hope this one is OK also. Found my new cheater pipe! Real photo. Wanted it the other way round but the steering shaft hole is too small.
A grouchy click from today as I stepped back from fighting with OT's. I put it on and thought
Cheater pipes hid while this looked at me from the corner. Test ME out.
When 330 ft lbs are out, grab the Century Tube, they're stout!
There's still soft grease inside and wiped right off the breaker bar. Actual photo.
				Nathan Pederson
Duey, that sure is a resourceful use of the column and also a very interesting description of the process besides!
Speaking of leverage, old T driveshafts make excellent pry bars. Grandpa always kept this one around the sawmill.
				robert daniello
- Last Name: D
Nathan Pederson wrote: ↑Sat Oct 21, 2023 4:13 pmMy TT needed doors.
Something that moves slowly, and a tortoise.
				Nathan Pederson
A perfect caption for the picture thanks to Robert!
				Nathan Pederson
