1926 Single seater speedster
Mr Model T Ford
Topic author - Posts: 13
- First Name: Andre
- Last Name: Wessels
- * REQUIRED* Type and Year of Model Ts owned: 10
- Location: Western Cape / Cape Town / Wellington / South Africa
I am building a 1926 Single seater speedster.
I am building a new engine from scratch,
what can a do to increase power on the engine
walber
- First Name: Walt
- Last Name: Berdan
- * REQUIRED* Type and Year of Model Ts owned: '18 Speedster had 25 touring and 26 coupe
Re: 1926 Single seater speedster
Power (speed) costs money. How fast do you wan to go.
a few hundred for a head, cam and carb.
Several thousand + if you want to beat the Wild Cherry on the hill climb.
Can't advise without some parameters for what you want.
Take a look at these sites you'll need to browse around a lot.
North West Vintage Speedsters
https://www.nwvs.org/Technical/MTFCA/MT ... cles.shtml
just a sample of the index These are different
https://www.nwvs.org/Technical/MTFCA/Ar ... edster.pdf
Tulsa Model T Club
https://mtfctulsa.com/Tech/
Tulsa Model T Club
Fast period correct or economy??
Number one increase the compression.
You can go with hi-dome pistons & a stock low or high head. Or go with stock aluminum pistons & a high compression head.
I highly recommend a Prus & do not recommend a Z head.
Cam: Stipe 280 super or Montana cam. Neither need advancing.
Model A manifolds & carb. Fuel pump or lower the carb.
P.S. a good distributor, Bosch front plate preferred.
Les Schubert
- First Name: Les
- Last Name: Schubert
As stated; how fast do you want to go. How capable are you. Also keep in mind that good brakes and handling are important. I’ve gone 100 mph!!
The real question for driving a Model T is how quickly do you want to stop. Once you have figured out how to achieve that stopping distance you can work on your engine performance, if necessary, to match it.
https://www.mtfca.com/discus/messages/3 ... 1368573238
Mr Model T Ford
- First Name: Andre
Thank you for all the links.
Can someone send me some video links of how to install a Model A crank in a Model T block please.
Don't seem to find any on YouTube how to install a Model A crank in a Model T block
Les Schubert
- First Name: Les
Andre
Two basic options;
1. Shorten the back of the crank
2. Move the block ahead 5/8”
I have done both
Two basic options;
I have done both
Mr Model T Ford
- First Name: Andre
Thanks LesLes Schubert wrote: ↑Fri Nov 24, 2023 12:26 amAndre
Two basic options;
I have done both
I think to move the block forward.
I bought the back spacer that takes the vw oil pump and the bigger oil sump for more oil volume.
I live in South Africa / Cape Town - Wellington and baying parts for the Model T is a bid challenge.
The knowledge here by us to install a Model A crank in a Model T block is not available
Les Schubert
- First Name: Les
You need heavier main bearing caps
With A rods you need special pistons. Some people have cut and welded the bottom of the A rods to the top of the T rods and then used ordinary T pistons
At the front of the A crank I’ve used a “Speedi Sleeve” to cover part of the front key so the packing will work there
