Engine Temp question - not what you think....
Gen3AntiqueAuto
Topic author - Posts: 415
- Last Name: Foye
- * REQUIRED* Type and Year of Model Ts owned: 27 Fordor, 15 speedster (2), 23 touring, 26 fordor, 25 TT
Has anyone figured out what the temperature of the oil/crankshaft/mains/rods is inside a Model T when running well (and also when boiling over)?
Gen III Antique Auto - we do Model T Ford Restorations
You can have everything in life you want, if you will just help other people get what they want -Zig Z.
https://www.youtube.com/channel/UCeROBg ... pB-KImprjw
Re: Engine Temp question - not what you think....
Haven't had the need to!
- Last Name: Hjortnaes
Hot. Hot enough to burn your fingers.
That would depend on a number of variables.
Around 200 F would be a good guess, and hotter under hard use and/or hot weather.
Art M
- First Name: Art
- Last Name: Mirtes
I have never measured the temperature of the crankcase. But after reading another topic, I am going to measure the temperature of the crankcase and of thr rear axle pumpkin. I know the pumpkin gets hot going up a long hill, but not sure about the crankcase temperature. The car has been put away for the winter..... I think.
Art Mirtes
Art Mirtes
- Last Name: Patrick
Probably the best way to obtain temperatures of various parts of the engine would be with an infrared temperature Gun. Simply point the laser pointer at the part of the engine you want to test and remotely obtain the temperature. You can get one from Amazon. Jim Patrick
AndyClary
- First Name: Andrew
- Last Name: Clary
To what end?
Andy
Andy
Kevin Pharis
- Last Name: Pharis
Till all the rotating parts turn blue and seize at about 400F!!!
Gen3AntiqueAuto
- Last Name: Foye
Here's the behind the scenes reason for the question. I could not find the "pinch nut" small block chevy rod nuts I normally use (what a messed up broken world this is) and after seeing what happened to the inside of this 25 engine I do not want to use cotter pins in it.
I did find some nylocs (after days of searching). We run nylon timing gears and they don't melt so the oil itself is not too hot - my concern was the "long stick on the other end of the explosions" getting too hot and softening the nylon locking part of the nut. I dont think it will but I was looking for info to prove the theory. Now I have the metal ones I wanted in the first place so I think it's all good.
AndyClary
- Last Name: Clary
Loctite works and I think it’s only good to around 400 degrees. You can get self locking stover nuts from Amazon in a couple days. My machine shop has the Chevy nuts by the gross.
Andy
Andy
Gen3AntiqueAuto
- Last Name: Foye
My machine shop had them by the box too - before they went out of business.
I explain this whole topic in this video: https://www.youtube.com/watch?v=lOBoudTRwA0
- Last Name: Hatch
If you can wait till tomorrow I will post the part number. I get them in a 500 count box from Engine Parts Wharehouse. Dan
