I have a question about the body mounting brackets on a 1914 and later roadster body. Do the rear brackets have round or square holes to mount them to the main sills? If square holes them the carriage bolts go from the underside of the body out through the brackets and the rear fender irons with the nuts on the outside. Is this correct? If the holes are round then what direction do the hex head bolts go?
Thank you
Craig
Body mounting brakets
Craig E. Luton
Topic author - Posts: 191
- First Name: Craig
- Last Name: Luton
- * REQUIRED* Type and Year of Model Ts owned: 1914 Ford Runabout; 1915 Ford Touring; 1936 Ford Pick-up
Re: Body mounting brakets
The body brackets with the square carriage bolt head are rear runabout only that I'm aware of - I've done 2 runabout bodies & that's what I used on the rear with the nuts outside of the fender iron & they not easy to find !
By james dimit on Monday, January 08, 2007 - 04:44 pm:Craig E. Luton wrote: ↑Sun Dec 03, 2023 10:46 pmI have a question about the body mounting brackets on a 1914 and later roadster body. Do the rear brackets have round or square holes to mount them to the main sills? If square holes them the carriage bolts go from the underside of the body out through the brackets and the rear fender irons with the nuts on the outside. Is this correct? If the holes are round then what direction do the hex head bolts go?
Thank you
Craig
Craig, these are the 3 different mounts on a 25 roadster I've been helping on. As mentioned the square holed ones go to the rear. --
