Distance from crankshaft to camshaft
Dave1
Topic author - Posts: 117
- Last Name: Eddie
- * REQUIRED* Type and Year of Model Ts owned: 1926 Tudor, 1926 Touring, 1931 Plymouth PA, 1952 Hudson Hornet
Anyone recall the centre to centre distance from the camshaft to crankshaft?
Dave
Dave
- Last Name: Tannehill
- Board Member Since: 2002
Re: Distance from crankshaft to camshaft
3.9375 I believe is the number you’re looking for.
Dan McEachern
- First Name: DAN
- Last Name: MCEACHERN
that is correct.
Steve Hughes
- Last Name: Hughes
- * REQUIRED* Type and Year of Model Ts owned: 1926 Touring 1921 Centerdoor
Otherwise known as 100 mm.
Les Schubert
- First Name: Les
- Last Name: Schubert
Steve is Correct!!
Les Schubert
- First Name: Les
20-30 years ago I was trying to figure out what the correct gear spacing was. I had a perfect set of early straight cut gears and upon studying them I realized that they were essentially metric pitch gears and then the numbers worked out. I made some links to use for setting up my line boring and I got perfect gear mesh every time. No more need for off size cam gears!
Dan McEachern
- First Name: DAN
"I read it on the internet, it must be true".
