Maximum diameter of the main bearing cavities
Dave1
Last Name: Eddie
* REQUIRED* Type and Year of Model Ts owned: 1926 Tudor, 1926 Touring, 1931 Plymouth PA, 1952 Hudson Hornet
Post by Dave1 » Mon Dec 18, 2023 6:57 pm
Wondering how far can you bore out the main bearing saddles, on not effect the process of pouring Babbitt?
The concern is if you expose the bolt holes the molten Babbitt will leak out
Re: Maximum diameter of the main bearing cavities
Post by Mark Gregush » Mon Dec 18, 2023 7:26 pm
When the Model A crank is used, you do cut into the top bolt holes just a little. When babbitt is poured, the bolt or locating pins will block most of the hole so only a little babbitt will get in. After the mold is removed, that can be drilled out. If needed, the putty used for blocking and damming when pouring babbitt could be used as needed.
Erik Barrett
First Name: Erik
Last Name: Barrett
Post by Erik Barrett » Mon Dec 18, 2023 9:16 pm
What Mark said. For a stroker crank job you have to hog the T block all the way out to the bolt holes. Before pouring I plug the holes up to prevent leaks.
Dave1
Last Name: Eddie
Post by Dave1 » Mon Dec 18, 2023 9:35 pm
Thanks for the tips
Kerry
Last Name: van Ekeren
Post by Kerry » Mon Dec 18, 2023 10:56 pm
Just the smallest of a hole will run hot babbitt like a river, the best plug I've found is house hold aluminium foil in the oil holes and exhaust sealer around the out side of the molds.
Dave1
Last Name: Eddie
Post by Dave1 » Mon Dec 18, 2023 11:27 pm
Kerry,
Aluminum foil I will have, exhaust sealer are you referring to header wrap or gasket material?
Dave
Kerry
Post by Kerry » Tue Dec 19, 2023 2:17 am
Dav
I use a high temp paste made in Newzealand by CRC, it seals hard as soon as I heat the block saddles, caps or rods with a 1" propane torch before poring babbitt.
/attachment]
Dave1
Last Name: Eddie
Post by Dave1 » Tue Dec 19, 2023 11:01 am
Thanks Kerry,
This will be my first crack at pouring Babbitt, thanks for the tips
Post by Mark Gregush » Tue Dec 19, 2023 12:16 pm
I have been using/doing the same as Kerry, but different brand.
Dave1
Last Name: Eddie
Post by Dave1 » Tue Dec 19, 2023 1:44 pm
Mark,
Which brand do you use?
Post by Mark Gregush » Wed Dec 20, 2023 1:32 am
Adding new post to bump up.
Post by Mark Gregush » Wed Dec 20, 2023 11:08 pm
Permatex Muffler & Tailpipe Sealer #80335
Not sure if water base or not, the package does not say, it is water cleanup. I found best is to make sure it is fully dried before pouring the babbitt.
Dave1
Last Name: Eddie
Post by Dave1 » Thu Dec 21, 2023 2:31 pm
Thanks Mark
