Maximum diameter of the main bearing cavities
Dave1
Topic author - Posts: 130
- Last Name: Eddie
- * REQUIRED* Type and Year of Model Ts owned: 1926 Tudor, 1926 Touring, 1931 Plymouth PA, 1952 Hudson Hornet
Wondering how far can you bore out the main bearing saddles, on not effect the process of pouring Babbitt?
The concern is if you expose the bolt holes the molten Babbitt will leak out
Re: Maximum diameter of the main bearing cavities
When the Model A crank is used, you do cut into the top bolt holes just a little. When babbitt is poured, the bolt or locating pins will block most of the hole so only a little babbitt will get in. After the mold is removed, that can be drilled out. If needed, the putty used for blocking and damming when pouring babbitt could be used as needed.
Erik Barrett
- First Name: Erik
- Last Name: Barrett
What Mark said. For a stroker crank job you have to hog the T block all the way out to the bolt holes. Before pouring I plug the holes up to prevent leaks.
Dave1
- Last Name: Eddie
Thanks for the tips
Kerry
- Last Name: van Ekeren
Just the smallest of a hole will run hot babbitt like a river, the best plug I've found is house hold aluminium foil in the oil holes and exhaust sealer around the out side of the molds.
Dave1
- Last Name: Eddie
Kerry,
Aluminum foil I will have, exhaust sealer are you referring to header wrap or gasket material?
Dave
Dave
Kerry
Dav
I use a high temp paste made in Newzealand by CRC, it seals hard as soon as I heat the block saddles, caps or rods with a 1" propane torch before poring babbitt. /attachment]
Dave1
- Last Name: Eddie
Thanks Kerry,
This will be my first crack at pouring Babbitt, thanks for the tips
I have been using/doing the same as Kerry, but different brand.
Dave1
- Last Name: Eddie
Mark,
Which brand do you use?
Adding new post to bump up.
Permatex Muffler & Tailpipe Sealer #80335
Not sure if water base or not, the package does not say, it is water cleanup. I found best is to make sure it is fully dried before pouring the babbitt.
