I remember that someone had posted a printed drawing of a Model T frame and with body measurements within the Forum. Have searched back to 2007 without success.
When a '24-25 T is acquired 'in a basket', re-assembly becomes tedious.
Hopefully someone has a handle on those drawings and will share? (Or tell me where to find them.) Thanks!
Drawings with frame and body dimensions/measurements
Marv K
Topic author - Posts: 198
- First Name: Marv
- Last Name: Konrad
- * REQUIRED* Type and Year of Model Ts owned: '26 TT Steel Cab ("ToyBox Twoo"), '25 Coupe ("Cranky")
- Board Member Since: 2010
"Let's Figgur it owt!" Just fix it (right), and make it work.....
Aah-OO-Gah! (and), "Happy T-ing!"
Re: Drawings with frame and body dimensions/measurements
Marv
Do a general internet search with the search info as “Model T Ford frame drawings and dimensions”. There will be a LOT of what you’re looking for come up. Maybe this may help you in what you need or at least some of it.
Been Here Before
- First Name: George John
- Last Name: Drobnock
Ken Buhler
- First Name: Ken
- Last Name: Buhler
- * REQUIRED* Type and Year of Model Ts owned: 1927 Roadster 1927 Coupe
- Board Member Since: 2012
Marv,
Are you asking for drawings of the wood structure? I have a package of the plans for a '25 coupe that I acquired because I have most of a '25 coupe in pieces. I am planning to sell all of it together but I could have the plans copied if that's what you need.
Work honestly
Stay true to your word
Get the job done right
If your asking where to start when you have a T frame and a pile of body parts the easiest way to begin figuring out where the body framework goes and where it’s attached the best way is this:
Assuming your T frame has been gone over for straightness and repair use two saw horses and lay the bare frame on them.
The mounting holes for the firewall brackets are pretty easy to find on the frame. Mount the firewall on the two brackets.
This will give you a starting point where the body will be mounted and the other body mounting points on the frame. It all starts with the firewall location.
I have a 24 T Coupe and this method worked fine for me.
If your using new body wood the two main frame rails can be positioned just right using the mounted firewall as a starting reference. This goes for most T bodies that I know of.
