Valve cover on a 26 motor
Topic author - Posts: 250
- First Name: Dennis
- Last Name: Brown
- * REQUIRED* Type and Year of Model Ts owned: 1926 Roadster pickup
Valve cover retainers
On the 26 motor did they use bolts or studs to hold the side cover on ?
- First Name: Robert
- Last Name: Jablonski
Re: Valve cover on a 26 motor
Bolts on our '26
B McCalley CD encyl states:
OCT 26 1925, (Engine production records) Began using bolts on the valve doors.
I believe the bolts have rounded tops like the head bolts & the generator bracket bolts.
- Last Name: Saylor
Yes, Domed Head, Stainless steel.
I don't believe Ford ever used stainless on T production.
Parts books suggest 1926 were studs & 1927 were nickle head bolts. BUT 1926 could be/were replaced with the later version
