What Have You Done to Your Model T in December
mbowen
First Name: Miles
Last Name: Bowen
Post by mbowen » Sat Dec 02, 2023 2:21 pm
Learned to put the top up solo!
I’ve only been in the hobby a couple of years, and I don’t much like driving my ‘24 Touring with the top up (not to mention it’s canvas and has the wrong window), so I’ve only put it up a few times when it was raining on tour, and experienced help was always available. I’m considering the Polar Bear tour planned as part of the MTFCI Annual Meeting in Dayton in mid-January, where it would be a good idea to have the top up, but it won’t fit in my trailer that way, so I thought it would be a good idea to really LEARN the process by doing it solo. I tried a couple of times from memory but didn’t get very far. I then watched Mitch Taylor’s YouTube video, and got it done by myself in about 10-11 minutes. Don’t let anyone tell you a one-man top isn’t. ;) The only downside to Mitch’s video is that I can’t get the theme music out of my head! :lol:
Miles
1924 Touring “Bonnie”
1925 Express Wagon “Clyde”
NealW
First Name: Neal
Last Name: Willford
* REQUIRED* Type and Year of Model Ts owned: 1911 Touring, 1929 Model A Tudor
Re: What Have You Done to Your Model T in December
Post by NealW » Sat Dec 02, 2023 3:01 pm
Mitch's videos are really helpful. I have only had "two man" top touring cars, so I can't speak to what it is like to take down or put up a later touring car top. For the first couple of years owning our 21 touring, My wife would always help me put the top up or down because we had a garage with a 7' door at the time. When I replaced the top on that car, I figured out how to put the top up and down by myself. It is really not that hard to put up/down a "two man" top by yourself once you learn how to do it. You do need to be in the car to reposition the front vertical bow when doing so though. I almost never had anyone help me do it after that.
After we sold the 21 and I restored a 1911 touring, putting the top up and down was almost as easy, but it does have a longer top bow that goes over the windshield. Still, it is pretty easy and quick to do it yourself, once you've practiced a bit. I've thought about taking a few pictures showing the process that I use to do so, but never got around to it.
Neal
Post by Jerry VanOoteghem » Sat Dec 02, 2023 6:36 pm
Miles,
You're a better man than I am! Proud of you! :)
mbowen
First Name: Miles
Last Name: Bowen
Post by mbowen » Sat Dec 02, 2023 7:51 pm
Miles,
I don’t know about that Jerry, I probably just got lucky. It actually surprised me when it went as well as it did.
Miles
Tmooreheadf
Last Name: Moorehead
Post by Tmooreheadf » Sat Dec 02, 2023 9:47 pm
The only way I can get our 24 touring top up and down is to stand on the back seat floor boards and raise or lower it from there. Make sure all the top bow arm joints move easily. A drop or two of some kind of lube keeps its irons from pitching side to side and binding in the process. Once you do it a couple times, it can be done in a couple minutes. My only problem is I forget how to do it due to the long times in between raising the top. I too prefer it down. The polar bear tour will be fun. It’ll be chilly. That’s why we are driving the coupe. There will be several brave folks driving open cars. I’m just not tough enough I guess!
su8pack1
Last Name: Kelly
* REQUIRED* Type and Year of Model Ts owned: 1925 Roadster
Post by su8pack1 » Sat Dec 02, 2023 10:55 pm
Winterized, and covered her up till Spring.
Sean Butler
First Name: Sean
Last Name: Butler
Post by Sean Butler » Sat Dec 02, 2023 11:44 pm
I, like Neal, can put up the top on my ‘11 touring by myself, fairly easily after some practice. He is correct that you need to be in the car - back seat for me, sitting then standing. It also helps to have strong wrists! I realized I would need to learn how to do this when I was hit with an unsuspected rain squall and was lucky enough to have several hands “on hand”. Those extra hands won't always be there. My wife and I developed a system of doing this quite quickly which is good because when I start yelling at her she just yells back so all is good :shock: . Tom makes another valid point; I’ve only owned my car for 8 or 9 months and I’m sure when I go to put the top up again, either by myself or with assistance, I will have forgotten several of the things that were starting to feel natural. Neal’s idea of pictures is a good one. If others think it is of value, I could make a video next season.
Sean Butler
Huntington Beach, CA
NealW
First Name: Neal
Last Name: Willford
Post by NealW » Sun Dec 03, 2023 7:53 am
Like Sean said, you need to be standing in the back seat area when putting it up or down. Part of the time facing forward when you unpin the front bow from the forward pivot point on the car, and then turning towards the back of the car as you reposition it to go in the holes for it on the rear top bow. The last thing that I do is reposition the very forward bow to its stowed location on the front bow.
For me, the very forward bow is the last to be repositioned when I put it down and the first to be repositioned when I put it up. Sometimes I don't reposition it at all, but I do always use the straps to secure the top bows before driving.
It does take a little practice, and some gymnastics, to do it by yourself. I really don't like relying on someone without any experience helping me with the process, as there is a higher risk of a well intended helper scratching the car with the front top bow than if I'm doing it all myself.
First Name: Dallas
Last Name: Landers
Post by Dallas Landers » Sun Dec 03, 2023 1:26 pm
I tried for 3 hrs yesterday to mount one of my new Goodyear tires on the rim. No go! Two rim sreaders, two wood blocks cut to fit the rim and a jack, still no go! Pretty much destroyed the rim. Now these tires are early 90's vintage but very soft. After defeat, I went in the house.
Today I went to the shop and installed all four tires on the rims and mounted them after searching my pile for another good rim. 3 hrs start to finish.🤦‍♂️
Mamma said there would be days like that.
Bob McDaniel
First Name: Bob
Last Name: McDaniel
Post by Bob McDaniel » Mon Dec 04, 2023 10:50 pm
Getting the 09 ready for the Christmas parade this weekend if the weather holds out.
Last Name: Humble
Board Member Since: 2006
Post by Humblej » Tue Dec 05, 2023 11:38 am
Rims zinc plated and new tires installed.
Nice day for a photo op. My freshly shod 1924 Runabout.
Joe Reid
First Name: Joe
Last Name: Reid
* REQUIRED* Type and Year of Model Ts owned: 1919 Coupe, 1920 Roadster, 1923 Touring, 1924 Roadster, 1913 Racer
Post by Joe Reid » Tue Dec 05, 2023 5:52 pm
Moved cars around getting ready for more snow.
TheSaintDiscJockey
First Name: Brooks
Last Name: Schlieben
* REQUIRED* Type and Year of Model Ts owned: 1923 TT
Post by TheSaintDiscJockey » Wed Dec 06, 2023 5:52 am
New rear fenders for the TT were finished by my machine shop guy.
Mounted to see how they fit.
Will remove for painting and reinstall.
CatGuy
Last Name: Hunt
* REQUIRED* Type and Year of Model Ts owned: '26 Runabout
Post by CatGuy » Wed Dec 06, 2023 9:39 am
Thanks to a friend coming over last night and braving the cold, I was able to get the throttle linkage sorted out and finally the carb can go to full closed and full open! Little steps to hopefully having a better running T next year!
Gracie'sDad
Last Name: Dow
Post by Gracie'sDad » Fri Dec 08, 2023 12:06 pm
Gave ol' Gracie an oil change, filled her gas tank full, added Stabil, ran the carb empty, put her battery on a maintainer, detailed her body, put her up on jacks, covered her with her cover and with a loving pat, promised to see her again in the Spring.
ModelTMitch
First Name: Mitch
Last Name: Taylor
* REQUIRED* Type and Year of Model Ts owned: 1924 Ford Model T touring
Location: https://www.fordmodelt.net (Manning Valley, NSW, Australia)
Post by ModelTMitch » Sat Dec 30, 2023 4:09 am
Hi Miles, Thanks for the reference to my video - it's definitely a pleasure to make the videos and even better knowing people are getting something out of it :)
To answer the original question, this month, I entrusted my Model T in the hands of my sister!
https://www.youtube.com/watch?v=NVK2Ev7sGaU
Enjoy :D
☆☆ ModelTMitch ☆☆
★ Website: https://www.fordmodelt.net
★ YouTube: https://www.youtube.com/@ModelTMitch
★ Twitter: https://www.twitter.com/modeltmitch
★ Car Club: https://www.glhac.org
micshotrodgarage
First Name: michael
Last Name: miller
* REQUIRED* Type and Year of Model Ts owned: 1926 & 27 Roadsters 1927 Roadster pickup
Post by micshotrodgarage » Sat Dec 30, 2023 11:56 am
Took some time to clean up the 1927 Roadster pickup I bought back in June, Winter project. Got a good helper too!
rickd
First Name: Rick
Last Name: Duquette
* REQUIRED* Type and Year of Model Ts owned: 1913 Touring, 1914 Touring, 1925 Touring, 1927 PU, 1955 T Bird, 69 Shelby GT 350
Post by rickd » Sat Dec 30, 2023 1:35 pm
I want to thank our Model T vendors and their supplier of body panels. I was closing in on finishing this 25 Touring and pulled the body, again, to install two new reproduction splash aprons after hammering, dollying and shrinking wavy spots in the originals for days to no avail. I tried to keep every panel on this car original but after painting and then installing these aprons today I couldn't be happier.
First Name: Austin
Last Name: Farmer
Post by 1925 Touring » Sat Dec 30, 2023 3:02 pm
Ive been working on rebuilding my transmission with the help of a fellow club member.
jwilliams81
First Name: Jarrod
Last Name: Williams
* REQUIRED* Type and Year of Model Ts owned: 1923 Touring with electric starter, low radiator
Post by jwilliams81 » Wed Jan 03, 2024 2:59 pm
My wife and I delivered Christmas cookies to our friends and family when it was 28 degrees out, top down and bundled up!
Helen, our Model A, received her front Christmas wreath. Hazel, our Model T, received her spare tire Christmas wreath.
The weather here in Cincinnati has been snow free so far.
2,137 miles driven in 2023, our second year of ownership. Happy New Year!
Bob McDaniel
First Name: Bob
Last Name: McDaniel
Post by Bob McDaniel » Wed Jan 03, 2024 6:36 pm
After 3 delays for rain we finally got to drive the 09 in the Christmas parade.
Then Christmas eve we put about 60 miles on the backroads of Tennessee in the 27 touring.
Art M
First Name: Art
Last Name: Mirtes
Post by Art M » Wed Jan 03, 2024 7:56 pm
Jarrod,
Your car Christmas decorations look nice. Glad you were able to put a lot of miles on the car. You beat my last year's record distance by about 125 miles and you work, which I haven't done in nearly 25 years.
Incidentally, I haven't found the snow tire chains yet. They have to be here. There are two bags of them. We haven't had any snow yet this year. We did have ice, which brings out the salt demons.
Art Mirtes
jwilliams81
First Name: Jarrod
Last Name: Williams
Post by jwilliams81 » Thu Jan 04, 2024 3:00 pm
Hey Art!
Thank you, Hazel sure does present well with the wreath on the spare tire. I tried to drive her as much as I could, even to work on several Fridays. I'm holding out hope that you find the snow chains eventually! We haven't had snow yet, but they are forecasting it for this weekend. We'll see how it goes. Happy New Year!
Jarrod
Jarrod,
Art Mirtes
