Question on early spindle arms
FATMAN
First Name: ROBERT
Last Name: BERGSTADT
Post by FATMAN » Wed Jan 03, 2024 2:53 pm
I have had a lot of early spindle arms but just ran across this pair they have a sharp bend a lot more than the standard early arms, what year were these used? Bob
Last Name: Wrenn
Re: Question on early spindle arms
Post by TWrenn » Wed Jan 03, 2024 3:12 pm
Those are weird! Can't help ya...even the judging guidelines don't show any like that. Aftermarket maybe? Different brand of car?
Mark Nunn
Last Name: Nunn
Post by Mark Nunn » Wed Jan 03, 2024 4:46 pm
Are wide-track spindle arms different from standard? I'm just throwing this out without ANY facts to fall upon.
Post by Allan » Wed Jan 03, 2024 5:15 pm
Clever thought Mark. If the tie rod and drag link are standard fitment on Wide tracks, it make good sense.
Last Name: Kuehn
Post by John kuehn » Wed Jan 03, 2024 5:37 pm
Any markings or T numbers on them?
FATMAN
First Name: ROBERT
Post by FATMAN » Wed Jan 03, 2024 6:05 pm
Ford script on one also part number
FATMAN
First Name: ROBERT
Post by FATMAN » Wed Jan 03, 2024 6:06 pm
T 270 A is on the one if you enlarge photo,Bob
FATMAN
First Name: ROBERT
Post by FATMAN » Wed Jan 03, 2024 6:07 pm
T 270 is on the other one
Post by TRDxB2 » Wed Jan 03, 2024 7:07 pm
The odd shaped spindle arms, with Ford part numbers, appear to be unused, perhaps a repro intended for a special purpose
FATMAN
First Name: ROBERT
Post by FATMAN » Wed Jan 03, 2024 9:33 pm
Not re pros 1 used they are original
Tbird
Last Name: Bird
Post by Tbird » Wed Jan 03, 2024 9:49 pm
I wonder if they were modified for some sort of Gow job back in the day?
M.Sinclair
First Name: Matthew
Last Name: Sinclair
* REQUIRED* Type and Year of Model Ts owned: 1921 Coupe
Post by M.Sinclair » Wed Jan 03, 2024 11:17 pm
That’s a pretty severe angle for a modification I’d think. Especially with cast steels tendency to snap.
Post by Wayne Sheldon » Thu Jan 04, 2024 6:13 am
Any chance they could be tractor? They have a really short wheelbase, requiring a sharper angle for the steering arms.
Model T spindle arms are not cast iron. They are steel, probably drop forgings. They can be bent cold or hot, and even welded without much trouble. I have straightened several wrecked ones in the past, and for one racing car needed to custom bend to clear the special suspension. That car I drove VERY hard! Never had a hint of trouble from it.
However, they can be broken. Just ask Ed Archer about the Baja Run!
First Name: john
Last Name: karvaly
Post by speedytinc » Thu Jan 04, 2024 7:59 am
I can confirm, they are NOT wide track.
FATMAN
First Name: ROBERT
Post by FATMAN » Thu Jan 04, 2024 10:06 am
More photos we had about 300 arms over the last 30 years when sorting we found these in 2 separate places bought at separate times what are the odds they match? Bob
Post by Allan » Thu Jan 04, 2024 10:23 pm
In the last photo there is absolutely no distortion in the part number and the maker's mark. This would suggest there is no modification to the arms, as these marks would be distorted in any bending. The mystery remains.
FATMAN
First Name: ROBERT
Post by FATMAN » Fri Jan 05, 2024 9:32 am
Could it have been made for some kind of racer or 1st year after 1 pc spindles? Bob
