Fore electric magnetizer
Nate22huckster
First Name: Nathan
Last Name: Fahrni
* REQUIRED* Type and Year of Model Ts owned: 1922 huckster, 1925 tudor, 1926 TT dump truck, 1927 tudor
Post by Nate22huckster » Wed Jan 17, 2024 7:29 pm
Hello, a club member is trying to find out information about his magnetizer and I thought I’d post it on here to see if anyone could help. Google has not turned up anything useful so far when searching “FORE ELECTRIC CO.” You can see a + and - symbol pressed into the wood next to the terminals. I’d like to find out what voltage to use and for how long to charge a magnet. We do know that this unit was used in the past and it is in good condition.
Art M
First Name: Art
Last Name: Mirtes
Re: Fore electric magnetizer
Post by Art M » Wed Jan 17, 2024 8:12 pm
I believe it was originally connected to a 6 volt battery. Don't leave it connected for very long or it will become toast.
Art Mirtes
J1MGOLDEN
Last Name: Golden
Post by J1MGOLDEN » Thu Jan 18, 2024 10:51 am
I own its grandfather that was made to charge magneto magnets.
Nate22huckster
First Name: Nathan
Last Name: Fahrni
Post by Nate22huckster » Thu Jan 18, 2024 10:54 am
James, what voltage does yours run off of and for how long do you charge the magnet?
dobro1956
First Name: Donnie
Last Name: Brown
Post by dobro1956 » Fri Jan 19, 2024 12:21 am
I do not think it is a "how long" type of thing as much as how many times to "hit it" with the voltage. When charging in the car it is almost an instant type of connection, you just do it multiple times. So my guess is to throw the switch multiple times in fast intervals. When charging in the car it is not how long you "cook" it but how many times you "hammer" it with electric jolts. When I charge in the car I use three 12 volt batteries wired to give me 36 volts. I never used a single magnet charger so I can not really give a good answer for them .
Nate22huckster
First Name: Nathan
Last Name: Fahrni
Post by Nate22huckster » Fri Jan 19, 2024 5:57 am
Thanks, that’s good to know. I’ve never recharged magnets before
J1MGOLDEN
Last Name: Golden
Post by J1MGOLDEN » Fri Jan 19, 2024 10:11 am
I use this Allen Magnet Charger for charging magnets, and it used 6 Volts.
Allen Magnet Charger.JPG (37.54 KiB) Viewed 1353 times
I Zap the magnet three times, laying on its side with a one inch over hang, flipped to the other side with a one inch over hang, and stood up in the middle area.
Each position gets a 5 second Zap.
Henry Ford says the magnet only has to lift an iron piston and they weigh about 2 1/2 pounds.
My magnets will lift two pistons taped together with no problem.
