Loose threads
Will
Topic author - Posts: 191
- First Name: Will
- Last Name: Copeland
- * REQUIRED* Type and Year of Model Ts owned: 1915, 1919, 1923 TT
Loose threads
Has anyone ever used aluminum foil around the sparkplug to tighten loose threads in an aluminum head. I think one of the plug hole threads in my aluminum high comp head are getting worn. I don't like the way it feels when I tighten the plug.
As Tom Sellick told Marston in the movie Quigley Down Under, I told you I dont have much use for handguns, I never said I didn't know how to use them!
Re: Loose threads
Is it a 14mm thread, or 1/2" pipe thread?
Will
- First Name: Will
Re: Loose threads
The plugs are 1/2 NPT
Re: Loose threads
The problem is easily solved by using adapters for modern plugs. Screw the adapter in once only, with the sealant of your choice, and then use modern plugs. You may not like the look though.
Les Schubert
- First Name: Les
- Last Name: Schubert
Re: Loose threads
1/2” npt Helicoil is available. I have the kit and have probably fixed at least a dozen over the years!
Re: Loose threads
When putting plugs in an aluminum head, Anti seize compound should be used to protect the head threads from galling.
Try some & see if the plug doesn't go in to far before tight. If you are not familiar with it, its basically aluminum powder & oil made into a paste.
Plug adapters are an option. I still put anti seize on the adapters.
Craig Leach
- First Name: craig
- Last Name: leach
Re: Loose threads
Hi Will,
If you don't like the looks of the modern plugs & adapters they can be made from the later crimp style 1/2" npt plugs so they look like 1/2" plugs Craig.
Will
- First Name: Will
Re: Loose threads
Thank you everyone.
Re: Loose threads
I have used aluminum foil in a steel head. The threads had gotten rusty and when I tightened the plugs some of the compression would cause oil bubbles to come up around the plugs. The aluminum foil seemed to seal them just fine.
