Burnishing?
BobShirleyAtlantaTx
Topic author - Posts: 361
- First Name: Bob
- Last Name: Shirley
Burnishing?
Please show the set-up you use to run your shaft in.
Re: Burnishing?
I blue/scrape any high spots and use Timesaver to set my rods and crank.
Mark Osterman
- Last Name: Osterman
Re: Burnishing?
I know what you mean by using the word burnishing for this but if there is an abrasive being used .. it’s something else. Even though the abrasive is fine you are grinding. I use burnishing two ways in my day job; gold leaf and putting a glossy surface on albumen photographic prints. In both cases the object to be burnished is rubbed with a tool only to make the surface smoother.
Ruxstel24
- Last Name: Hanlon
Re: Burnishing?
Burnishing to me means "heat"...
I recall the term mostly in automatic transmission clutch plates. Some rebuilders will slip the clutches purposely, after a rebuild to smooth out the clutches. Supposedly this helps with smoother shifts/clutch application.
Not a big believer myself.
Torque converter lock-up clutches on some vehicles, had a break-in procedure that was activated through the computer to basically slip the clutch for a couple hundred miles after replacing a converter.
Adam
- First Name: Adam
- Last Name: Doleshal
Re: Burnishing?
Burnishing or running in is not necessary if the surface finish and dimensional tolerances of the crankshaft and main bearings is good.
“Running In” as Ford specified was to correct the fits and tolerances in case the machining was sloppy. In most cases it was. The act of “liberally oiling the bearings and running in the mains until the bearings smoke” was to provide a fairly precise fit without high precision measuring, without high precision machining, and with only a moderately skilled mechanic doing the work. The temperature that the oil smokes at is the temperature that the journal has expanded enough to provide proper oil clearance once everything has cooled.
D.Yoder
- First Name: DEAN
- Last Name: YODER
- * REQUIRED* Type and Year of Model Ts owned: 19tour,24tour,25rdpu,27rd.26coupe,TT's,& tractor conversions
Re: Burnishing?
Charley I like it more pictures please
Adam
- First Name: Adam
Re: Burnishing?
Where is it? It needs to go to the Model T Museum!
HornsRus
- First Name: Charley
- Last Name: Shaver
- * REQUIRED* Type and Year of Model Ts owned: 1913
Re: Burnishing?
don't worry about it it is in my museum.ha ha. charley
- Last Name: Hatch
Re: Burnishing?
Charley: Email went. Thanks, Dan
HornsRus
- Last Name: Shaver
Re: Burnishing?
scrap maybe not,as i have been offered $5000.00 for it.oh looks like sandblast and go to work. charley
Kerry
- Last Name: van Ekeren
Re: Burnishing?
How is it driven? is it flat belt on the drum or are the inturnals of the drum an electric motor?
This diagram shows the complete engine has a fuel line, is the engine being driven or for driving?
HornsRus
- Last Name: Shaver
Re: Burnishing?
it is run off line shaft,but motor can do the work, also motor can be started with it. charley
Adam
- First Name: Adam
Re: Burnishing?
If the engine was driving the crank in the bare block as shown in the picture, it would be turning the crankshaft in the wrong direction.
HornsRus
- Last Name: Shaver
Re: Burnishing?
do you think it would matter??????????? charley
Kerry
Re: Burnishing?
Found an original ad, my question answered, for running in the complete engine as well, neat tool wish I had one
HornsRus
- Last Name: Shaver
Re: Burnishing?
kerry i saved mine from the scrapman 30 years ago at an auction for $60.00.maybe you will get lucky to.charley
Randall strickland
- First Name: Randall
- Last Name: Strickland
Bill Crosby
- First Name: Bill
- Last Name: Crosby
- * REQUIRED* Type and Year of Model Ts owned: 1916 Touring, 1920 Coupe, 1926 RPU, 1927 RPU, 25 speedster project
Re: Burnishing?
After I finish line boring I burnish the Bearings to the crank with time saver in the same setup.
Take a look @ www.youtube.com/watch?v=pJRMptqPNB4
