Strange hole in wire wheel hub
lcleeton
Topic author - Posts: 12
- First Name: Lawrence
- Last Name: Cleeton
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1926 Runabout
On my recently acquired 26 Runabout, one of the five wire wheels has this hole in the hub. Any ideas why it is there? I've considered it could be used for some kind of lock like a bicycle cable lock, but there doesn't seem to be a way to use a cable lock on the spare tire mount.
got10carz
- Last Name: Meixner
Re: Strange hole in wire wheel hub
My only guess is it's there to access a grease zerk tapped into the hub.
A grease zerk in the hub isn’t a bad idea. Slowly turn the wheel to see if you can see one.
I wouldn’t worry about it either way unless you’re a purist.
- Last Name: Humble
A lot happens over the course of 100 years with different owners and mechanics making their mods and inflicting abuse, some sort of port for greasing the hub is a good guess. Hard to tell from the picture, is that chipped paint or a hole next to the lug nuts?
- Last Name: Hjortnaes
That is for the cicadas to rest during the day.
lcleeton
Just chipped paint with some rust behind it. I'm going to restore the wheels.Humblej wrote: ↑Sat Feb 03, 2024 8:36 pmA lot happens over the course of 100 years with different owners and mechanics making their mods and inflicting abuse, some sort of port for greasing the hub is a good guess. Hard to tell from the picture, is that chipped paint or a hole next to the lug nuts?
nicklm
- First Name: Nick
- Last Name: Miller
- * REQUIRED* Type and Year of Model Ts owned: 1926 touring
If you have a mounting for a spare in the middle of the back of the car, it could be for a wire for a stop light.
