1913 Model T Ford Exhaust Pipe
dllr28bl
Topic author - Posts: 97
- Last Name: Woolf
- * REQUIRED* Type and Year of Model Ts owned: 1913 Touring
Looking for information on the original Ford drawings for the 1913 Model T exhaust pipe. According to Bruce McCalley’s book, Model T Ford, The Car That Changed The World, in 1913, “the exhaust manifold was modified during production to use the flanged exhaust pipe, instead of having the pipe fitting into the manifold and being sealed with asbestos packing.” Does anyone have the drawing number or part information so that I could purchase the drawings from the Benson Ford Research Center?
Thanks,
Dan
Thanks,
Dan
Re: 1913 Model T Ford Exhaust Pipe
Quite sure Larry "Original" Smith might be able to assist on that.
dllr28bl
- Last Name: Woolf
Thanks, Steve. I was thinking he might have that info.
Tbird
- First Name: Mike
- Last Name: Bird
Dan, so the part number is T4037B and the drawing number is T1829dllr28bl wrote: ↑Thu Feb 08, 2024 3:08 pmLooking for information on the original Ford drawings for the 1913 Model T exhaust pipe. According to Bruce McCalley’s book, Model T Ford, The Car That Changed The World, in 1913, “the exhaust manifold was modified during production to use the flanged exhaust pipe, instead of having the pipe fitting into the manifold and being sealed with asbestos packing.” Does anyone have the drawing number or part information so that I could purchase the drawings from the Benson Ford Research Center?
Thanks,
Dan
You're right on the difference with the straight pipe that slid into the manifold vs the flange.
The Henry Ford has an exhaust pipe drawing T1214 for a 1919 uploaded digitally on their website. The drawing is dated for 1919, but the overall pipe shape didn't change. I think in 1919 they started adding a Ford Script stamp to them. You can purchase a high res drawing I think for like $7
You can contact the Henry Ford and ask them to see if thy have the drawing for T1829 those drawings not already uploaded are $30 a piece.
Here's a link to the drawing. https://www.thehenryford.org/collection ... act/465554
Mike
dllr28bl
- Last Name: Woolf
Thanks so much for the information Mike! I really appreciate it!
Dan
Dan
And as far as we know Benson Ford library is shut down til further notice
Think this is it not sure
- Attachments
- Ford drawing tail pipe.jpeg (33.71 KiB) Viewed 1877 times
Tbird
- First Name: Mike
- Last Name: Bird
Ive ordered drawings from them recently… didn’t seem to have any problems…
Unless I'm confusing things, if the "library" and the "research center" aren't indeed the same? I remember seeing something on their website, yes, several months ago saying they were closed with no date set to reopen. I even sent in a request for a build sheet almost a year ago now and have yet to hear from them, but they sure did cash my check okay!! I gotta try contacting them again. Maybe they're up and running now.
