Help ID mystery brackets. Model T?
signsup
Last Name: Brough
* REQUIRED* Type and Year of Model Ts owned: 1915 War Wagon 1927 Depot Hack 1927 TT
Post by signsup » Wed Feb 07, 2024 8:59 pm
The one curved one fits my 27 steering column, but it has a bracket welded onto it, so don't know. The other two brackets sure look like a right hand and a left hand, but I can't see them as firewall to frame brackets. Some sort of body mounts? Or nothing T related. Just want to find a good home for them
Thanks in advance.
A bunch of old cars
Sometimes they run.
Sometimes, they don't.
1923Touring
First Name: Joshua
Last Name: Hawkins
Re: Help ID mystery brackets. Model T?
Post by 1923Touring » Wed Feb 07, 2024 9:41 pm
I think the two l-brackets are used to connect the front cross member to frame. Those would be R and L specific. I have no idea for the other piece.
-Joshua
Post by DanTreace » Wed Feb 07, 2024 10:05 pm
The single part is the lower steering column dash clamp for a '26-'27
Post by TRDxB2 » Wed Feb 07, 2024 11:48 pm
Mystery solved!
signsup
Last Name: Brough
Post by signsup » Thu Feb 08, 2024 10:07 am
Thank you, Holmes and Watson. Steering dach clamp makes sense with my projects, but the TT frame brackets are a mystery how they got in my stash. I'll blast them and prime them and find a good home for them.
Thanks to all.
A bunch of old cars
Sometimes they run.
1923Touring
First Name: Joshua
Last Name: Hawkins
Post by 1923Touring » Thu Feb 08, 2024 4:55 pm
Unless I am missing something, I would think you would need to measure them before presuming they are TT. The angle brackets look the same as on the car.
signsup
Last Name: Brough
Post by signsup » Thu Feb 08, 2024 5:25 pm
Good point. I'll compare them to my 27 frame and my 20 frame before I represent them as TT
A bunch of old cars
Sometimes they run.
signsup
Last Name: Brough
Post by signsup » Tue Feb 13, 2024 9:23 am
Was just reminded I never reported back to bring closure to a thread which always bothered me on forums. So, anyways, this is definately a TT bracket which connect the front cross member to the TT frame. Rivets to the backside of the cross member and up the side of the frame rail. The similar brackets on the two T frames I have access to have the bracket riveted to the backside of the front cross member but the side frame rail sits on top of the arm of the bracket, so the T brackets have an additional bend to the frame mounting arm
Similar in overall dimensions, but the T brackets have an additional bent wing to them.
A bunch of old cars
Sometimes they run.
