Center main bearing cap question
blauvelt
First Name: Douglas
Last Name: Ogden
Post by blauvelt » Sat Feb 17, 2024 2:14 pm
Anyone seen a cap like this? Are the adjustments for thrust uptake?
Re: Center main bearing cap question
Post by RajoRacer » Sat Feb 17, 2024 2:39 pm
I have several types but not like that one !
Kerry
Last Name: van Ekeren
Post by Kerry » Sat Feb 17, 2024 2:42 pm
With the 2 grub screws only to adjust one way, I'd say it's purpose is to close the mag gap.
Last Name: Kuehn
Post by John kuehn » Sat Feb 17, 2024 4:27 pm
It’s an adjustable main cap. A old trick to get you by with an original cap is to use a rat tail file and slot the holes enough to move it in closer. The best location to do this is with the rear main to lessen the end play.
RVA23T
Last Name: C
Post by RVA23T » Sat Feb 17, 2024 7:57 pm
I took the liberty to adjust the picture.
blueworlds adj main cap.png (408.18 KiB) Viewed 1327 times
Everything works in theory.
Reality is how you determine if something works or not.
Craig Leach
First Name: craig
Last Name: leach
Post by Craig Leach » Sun Feb 18, 2024 1:43 pm
Hi Douglas,
This is one I picked up a few years ago, it's a little simpler design but should work the same. I would bet it was a fast repair for a otherwise
time consuming repair.
Craig.
Post by Rich Eagle » Sun Feb 18, 2024 2:22 pm
There is always something new here to see!
Thanks for posting these.
Post by DanTreace » Mon Feb 19, 2024 11:38 am
Adv for that type of cap to manage end-play.
And a couple of more devices to keep the mag strong ;)
