KRW Generator Test Meter
Brian D
Topic author - Posts: 205
- First Name: Brian
- Last Name: Dowell
- * REQUIRED* Type and Year of Model Ts owned: 14 Touring 26 Runnabout 19 Canadian Touring
Was able to obtain this meter.
Looks pretty easy to use, however before I guess on hooking it up I'll be humble enough to ask first.
How do I use and/or test.
Brian
586 864 5110
Brian
586 864 5110
Life is Good, be nice.
Re: KRW Generator Test Meter
Brian,
How did we miss the fact that the meter says "Amperes"??? I totally missed that the other day!
GG Gregory
- First Name: GG
- Last Name: Gregory
- * REQUIRED* Type and Year of Model Ts owned: 27 Roadster
I have one like it, and also a KR Wilson mag tester which looks like the amp meter. I’ve never known how to use them.
dykker5502
- First Name: Michael
- Last Name: Deichmann
I'll assume it is a regular amperemeter, so setach the wire on the generator and connect to the one terminal om the meter, and do a wire and connect the other terminal to the generator. Start the engine. If the needle goes "negative" swap the wires on the meter.
Ford Model T 1914 Touring
Connect to output post on the generator cutout not the battery side. The battery side would be same as connecting to battery, that post on the cutout would be same as battery voltage.
GG Gregory
- First Name: GG
Good info. How would the mag tester I have work? One to the mag post and one to a ground on the car? I’m a little afraid to touch anything to the mag post in fear of dis charging the mag
AdminJeff
- First Name: Jeff
- Last Name: Stevenson
I wonder what the internal load resistance is? I'm sure it's a wound coil of some sort.
Assistant WebSite Admin
www.modeltregulators.com
www.modeltstarters.com
