Brass ring gear screws, change them or leave then alone?
Paperman
Last Name: Kesling
* REQUIRED* Type and Year of Model Ts owned: 1927 Tudor
Post by Paperman » Tue Feb 20, 2024 7:41 am
I have a 1920 engine torn down for some cleaning and a once over. Mag works fine and is in original condition. The flywheel magnets and retainers are all there and in fine shape. Does one change the brass screws for new as a precaution? I have 2 other engines with damaged mags due to a broken screw that let the retainer smack a coil or three.
John.Zibell
Last Name: Zibell
Re: Brass ring gear screws, change them or leave then alone?
Post by John.Zibell » Tue Feb 20, 2024 8:01 am
Since it is apart, I'd re-charge the magnets. You don't know how much longer they will hold a charge. That would require new screws. Be sure to get the correct ones for you ring gear. Even if you don't charge the magnets I would recommend replacement since it is apart.
1926 Tudor
Post by John kuehn » Tue Feb 20, 2024 8:41 am
You mentioned you have the engine torn down. Has the mag ring ever been replaced? If it looks like it has good insulation it may be OK. If the insulation is an oily black color it probably hasn’t. When everything is easy to get to in a tare down that’s the time to do it. After 100 years with original parts the internal parts really need an evaluation.
NealW
First Name: Neal
Last Name: Willford
Post by NealW » Tue Feb 20, 2024 8:52 am
A new set of brass screws is pretty cheap from the vendors. Those screws are 104 years old in that engine and could be brittle by now. I've replace the screws both times I've rebuilt a T engine, and the old ones seemed pretty brittle when I replace them, including at least one having the screw head easily break off.
By the time you're that deep into an engine, replacing the brass screws, valve springs and clutch spring is well worth it to me.
Post by Jerry VanOoteghem » Tue Feb 20, 2024 10:44 am
I think you've answered your own question... ;) :)
Any relation to Keith Kesling? He was a professor of mine when I attended Lawrence Tech, soooo many years ago.
Paperman
Last Name: Kesling
Post by Paperman » Tue Feb 20, 2024 12:52 pm
Not that I am aware of. I have an "interesting" family history, an adoption soon before immigration tossed a wrench in the works. Spurred on by an illegitimate child of a nameless preacher in the old country marked the end to the beginning of my linage.
Post by Jerry VanOoteghem » Tue Feb 20, 2024 2:00 pm
Wow. Yes, interesting indeed...
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Tue Feb 20, 2024 5:21 pm
"A picture is worth a 1000 words........."
RVA23T
Last Name: C
Post by RVA23T » Tue Feb 20, 2024 6:09 pm
Chosen News Paper on Purpose?
Dan McEachern
First Name: DAN
Post by Dan McEachern » Tue Feb 20, 2024 8:03 pm
Actually no, but when I went to snap the picture I just could not resist leaving the newspaper headline there! That was just the chunk of newspaper we grabbed when we took the shrapnel out of the pan. Perhaps there IS a higher power out there somewhere eh?
First Name: Austin
Last Name: Farmer
Post by 1925 Touring » Tue Feb 20, 2024 9:46 pm
Ive been rebuilding my transmission for my t with some help, and got a new ring gear. The new ring gear screws are different than the old oroginal ones. the brass screws also didnt want to stay tight, and the plates would wiggle. ended up habing to put locktite on both ends.
Post by RajoRacer » Wed Feb 21, 2024 11:15 am
The original screw was a #14-28 - repros for the repro ring gears are 1/4-28 - they don't "mix & match" !
Post by John kuehn » Wed Feb 21, 2024 11:24 am
Rajo is right. The information about the correct ring gear screws has been out there for several years. If I remember the vendors list that in their sales information.
Post by speedytinc » Wed Feb 21, 2024 11:26 am
The original screw was a #14-24 - repros for the repro ring gears are 1/4-24
Post by RajoRacer » Wed Feb 21, 2024 11:30 am
Thanks for the correction - still early !
jab35
Last Name: Bartsch
Post by jab35 » Wed Feb 21, 2024 11:39 am
Last Name: Tannehill
Board Member Since: 2002
Post by JTT3 » Wed Feb 21, 2024 11:59 am
Austin I can’t imagine that having a positive long term result. I really hope I’m wrong. Best John
Dan McEachern
First Name: DAN
Post by Dan McEachern » Wed Feb 21, 2024 1:28 pm
Austin- you said "the screws would not stay tight". Something is wrong or you simply have not torqued the screws tight enough. Those screws MUST be tight enough to firmly clamp the plate to the magnets. You should not be able to move the plate after the screw is torqued. Pleas get someone knowledgeable to help you with this. Loctite is not the solution!
