It runs ... just poorly on magneto
vping
Topic author - Posts: 251
- First Name: Vincent
- Last Name: Pina
- * REQUIRED* Type and Year of Model Ts owned: 1925 Tudor Sedan
Starter problems solved by cleaning and adding a ground strap.
Starts and runs great, and I can rev up rpms and sounds good.
When I switch to magneto it runs poorly and when I rev the rpms, it sputters.
I cleaned the mag pickup which did have fuzz on it and jiggled ignition key (no change) and it still runs poorly. Back to battery and it runs great.
What are my next steps to check?
Re: It runs ... just poorly on magneto
Check magneto output voltage with an analog meter.
When confirmed too low, do an in car magnet recharge.
vping
- Last Name: Pina
Yeah I read that somewhere. Exactly how do I check? 1 lead to pick up and 1 to ground?
Also what if I only have a digital meter?
vping
- Last Name: Pina
I'm running a dizzy. Does that change anything?
vping
- Last Name: Pina
Thanks for all the responses and patience John. Explain that last sentence please. Can I run on just battery?
If you have a generator motor(19-27), the generator keeps the battery charged & yes, you run on battery only with a dizzy.
If you had an earlier motor & needed to keep the battery charged, you could convert your magneto to DC voltage output to keep the battery charged.
vping
- Last Name: Pina
Got it. Ok so far so good then. I think I ran out of gas now because it won't start lol. Thanks for all of your help
