Chev valve spring keepers and retainers
Steve King
Last Name: King
* REQUIRED* Type and Year of Model Ts owned: 14 Touring, 25 Coupe, , 26 Touring, 22 Aluminum Fordor, 23 Coupe
Board Member Since: 2010
Post by Steve King » Mon Feb 26, 2024 11:34 am
I am finishing a late 13 block someone else started. The block has had seats installed, ground and guide reamed to accept what I believe are chev valves that have been included. The valve dimensions are 5.103" long. 1.506" head diameter. .3415" stem diameter. They have 1 notch about. 90" or more wide for the keepers. The slot diameter there is .3003". What keepers, spring retainers, and adjustable lifters would I need to complete the job? Part numbers, source? I tried 6 times turning my camera every way but no success uploading pictures. I've uploaded here before, but not today.
First Name: craig
Last Name: leach
Re: Chev valve spring keepers and retainers
Post by Craig Leach » Mon Feb 26, 2024 12:46 pm
Hi Steve,
Chaffin's has them part# 3056M 8 required & 3057M 8 pr. required.
Steve King
Last Name: King
Post by Steve King » Mon Feb 26, 2024 1:05 pm
Thanks Craig!
Post by Jerry VanOoteghem » Mon Feb 26, 2024 1:47 pm
For lifters 3058B, C, D or E, Chaffin's.
Don't get the self-locking style.
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Mon Feb 26, 2024 2:41 pm
The 9N tractor retainers are the best fit with chebby valves and T springs. The chebby valve keepers work with the tractor retainers. I’ll get part numbers tonite if nobody else offers em up before…
Plankhill
First Name: Brendan
Last Name: Doughty
* REQUIRED* Type and Year of Model Ts owned: 16 , 21, 24, Touring , 24 Roadster, 26 Speedster
Post by Plankhill » Mon Feb 26, 2024 7:05 pm
Jerry
Have you had problems with the self locking lifters?
kelly mt
Last Name: Kelly
Post by kelly mt » Mon Feb 26, 2024 7:25 pm
I did the T springs, 9-N Ford tractor retainers and Chevy valves and keepers also. It all fits together real good. Also adjustable lifters.
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Mon Feb 26, 2024 10:36 pm
Pioneer single groove valve lock PN PF555-HD
GM Spring Retainer PN 10038209
First Name: craig
Last Name: leach
Post by Craig Leach » Mon Feb 26, 2024 11:21 pm
Classic Keepers sells a keeper that moves the retainer up .060 to give a better installed spring height. P/N 1060-100 that number is for 100 pairs
for 11/32 valves. there should be someone that will sell smaller quantities. Model A springs will give a greater spring pressure just in case you
plan on getting more than 3000 rpm out of your T.
Post by Allan » Tue Feb 27, 2024 6:52 am
I have a dandy little valve spring compressor which make installing caps and collets [keepers] much easier. It is a period piece with jaws which open in PARALLEL, and click open that way when set, leaving both hands free. This means the cap stays central on the valve stem, allowing easy fitment of the two collets. The scissor type valve lifters cock the spring and cap sideways, making installing the collets very difficult at times.
I can post a photo tomorrow if anyone is interested.
