Down Draft Intake Manifold Info
Topic author - Posts: 552
- Last Name: Meixner
Anyone have any idea what this manifold was intended for when new. I don't believe Model A due to the port shape. I know what the carb is from, and dont know if that's a clue or not. My only guess is Iron Duke Chevrolet.
- First Name: Terry
- Last Name: Woods
Re: Down Draft Intake Manifold Info
The slotted mounting ears look just like a Model A, B or C, but unless the posts are round (they don't look round in pictures), it probably isn't Ford.
- First Name: Kevin
- Last Name: Pharis
Looks like a special built for T with the ports enlarged. If it were a factory produced part for some other application there would likely be one or even several casting part numbers, patent dates, etc…
- First Name: Joe
- Last Name: Bell
Wish I found it , zoom zoom!
- First Name: Douglas
- Last Name: Ogden
Used one, not the best flow, and can ice up something fierce. Ported block to match. Ran it with a 1 5/8 Master carb with the air screw removed, Giant head and a custom Crower ground A cam (later learned it is a stock grind from an MGA). Set up Fouled plugs like it was protesting CARB. That said, gave power well past 80 mph w/3.63's and a warford. The things we learn!
- First Name: craig
- Last Name: leach
I'm with Kevin 153 Chebby bolts are staggered.
Craig.
Craig.
- First Name: Mike
- Last Name: Penserini
- * REQUIRED* Type and Year of Model Ts owned: 27 roadster pickup, brass speedster, Mercury # 253 B, Mercury # 1070, Faultless "Hoosier" parts collection.
Steve, It's made to fit a Model T, I have one too, mine is pretty old. I believe it was originally intended as an updraft. Horizontal ports were used in T blocks back in the day. Photo of is the Ed Winfield engine, not mine !
- First Name: Les
- Last Name: Schubert
I made variations of this over the last 40 years. My earliest version utilized a Corvair Turbo. Unfortunately I had installed a quite “radical” camshaft and the car had a terrible low speed performance! I have continued to make variations of this design but I now divide it for about 6” of the flow length and then I can use a quite radical camshaft.
Just my experience
Just my experience
- First Name: Les
