Is this a 1921 or older Model T?
Chris Bamford
First Name: Chris
Last Name: Bamford
* REQUIRED* Type and Year of Model Ts owned: 1924 Speedster 1926 Touring
Post by Chris Bamford » Wed Feb 28, 2024 12:16 pm
I think not, but I'm captioning this photo for our local club newsletter and would like to be sure. The photo is dated August 1921 and the setting is the Pembina River at Evansburg, Alberta. The ferry was replaced by a single-lane road bridge in 1923.
The rail bridge in the background has an interesting history... it was built in 1909-10 in Scotland, disassembled and shipped to Canada and across the prairies to end-of-steel at Evansburg, then erected by means of a temporary wooden trestle bridge. Railway line construction continued from there, eventually reaching the ports of Prince Rupert and Vancouver in British Columbia. This single-track Evansburg rail bridge (at 214' the second tallest in Alberta) is still in use on the Canadian National main line and carries an average 20 trains daily.
Erik Johnson
First Name: Erik
Last Name: Johnson
Re: Is this a 1921 or older Model T?
Post by Erik Johnson » Wed Feb 28, 2024 12:23 pm
It's not a Ford automobile.
Chris Bamford
First Name: Chris
Last Name: Bamford
Post by Chris Bamford » Wed Feb 28, 2024 3:08 pm
Thank you Erik
Post by John kuehn » Wed Feb 28, 2024 3:16 pm
Isn’t that a Dodge? The front hubcap looks like a Dodge Brothers.
Post by TXGOAT2 » Wed Feb 28, 2024 3:51 pm
Dodge fenders look a lot like late Ford T fenders.
Post by Mark Gregush » Wed Feb 28, 2024 4:13 pm
Not Dodge Brothers. The spare tire would be slanted out at the bottom because of gas tank location and unless Canadian DB's had different windows, not DB.
Post by TXGOAT2 » Wed Feb 28, 2024 4:23 pm
Dodges had the gas tank mounted between the rear frame horns. They had a small, box-like cover at the rear of the running boards that gave access to the forward rear spring pin lubrication point.
Post by John kuehn » Wed Feb 28, 2024 5:45 pm
Anybody else have an idea what the car is? Not a Ford or Dodge evidently. But a car around the same size.
Tadpole
First Name: Tad
Last Name: Glahn
Post by Tadpole » Wed Feb 28, 2024 6:42 pm
My quick guess would be it is a late teens or early 20's Gray-Dort assembled in Ontario from American Dort parts, Gray having no relation to the Gray engine maker. Here are some photos I pulled from Google and a little snippet of their history: https://www.vdfhs.com/resources/5252/20 ... fGray.html
Thank you for the post and history! Always good to learn about the past no matter where or when.
