Rocky mountain brakes, has anyone used cable instead of rods?
1925TT
First Name: Forest
Last Name: Ledbetter
* REQUIRED* Type and Year of Model Ts owned: 1925 TT Holmes tow truck
Board Member Since: 2014
Post by 1925TT » Sat Jun 01, 2019 4:57 pm
Have a set of Rocky mountain brakes for a TT, but no rods. We can build rods, but we are playing with the idea of using cable instead. Not sure if anyone has given this a shot before and if they ran into any issues.
Susanne
First Name: Susanne
Last Name: Rohner
Re: Rocky mountain brakes, has anyone used cable instead of rods?
Post by Susanne » Sat Jun 01, 2019 7:04 pm
The rods give you an option of a POSITIVE release... with cables, you're relying on a spring, and if you need to get that pedal up to stop a single wheel lockup, and you're hoping a spring will save you...
Thats why they used rods. They knew you may need to pull up that pedal to unlock a sliding wheel, and springs and cables, while fine on modern juice brakes, wouldn't provide a negative "pull" to maybe save your butt.
You're talking 100 year old technology... please remember they also had safety in mind, but it was for the technology your car had. My car's run fine with rods AS LONG AS I inspected it and serviced it.
Last Name: Strange
Post by CudaMan » Sat Jun 01, 2019 7:10 pm
I'm using a home-built hybrid equalizer / cable setup on my period (not reproduction) AC brakes. I plan to use the same setup with my early reproduction Rocky Mountain brakes (whenever I install them). :)
JvanMaanen
First Name: Jim
Last Name: Van Maanen
* REQUIRED* Type and Year of Model Ts owned: 15 Touring, 19 roadster, 22 Coupe, 08 SR
Post by JvanMaanen » Sat Jun 01, 2019 7:33 pm
I tried this on my 22 coupe with original AC's and hassle shocks, found it easier to use rods and guides, the routing of cables was somewhat difficult, you could just bend the rods. Also the rods allowed me to put a little pressure away from the wheel on the brake shoes, giving me some much needed space.
Jim
Post by RajoRacer » Sat Jun 01, 2019 9:47 pm
Original Rocky Mtn. Brakes used cables.
Pops
First Name: David
Last Name: Houston
* REQUIRED* Type and Year of Model Ts owned: 13,14,19,21,&etc
Post by Pops » Sat Jun 01, 2019 10:31 pm
Hello Steve: Are you saying cables are better or just as good as rods?? What is prefurded ??? Thanks
Post by RajoRacer » Sat Jun 01, 2019 11:01 pm
I've run both and they're both pretty equal - cable actuation relies heavily on the equalizer assembly design - rods & the currently available equalizer are pretty straight forward in the Engineering Dept.
Post by Mark Gregush » Sun Jun 02, 2019 11:18 am
I am thinking that if X amount of force is being applied the rods will more directly apply that force. That being said, I would use ether. If I was using an original set of real Rocky Mt brakes I would use cable as they were made to use, modern I would use rods. A friend has the modern small drum AC's on his car, he did set them up with cables and have been working fine. I have big drum repo AC/Rockies on my 21 that I made my own equalizer and run rods, they work fine. This is a bad photo but is the only one I have right now. While it hangs off the parking brake cross shaft it goes under it and is independent of the shaft.
Post by Scott_Conger » Sun Jun 02, 2019 4:41 pm
As stated before, wire rope was the original standard.
That said, a modern mechanic, not versed in the use and termination of wire rope could easily get into real trouble compared to using solid threaded rods and clevis'.
This is NOT a recommendation or perjoritive on either method. Just know what you're doing and understand the system that you choose.
Post by Original Smith » Sun Jun 02, 2019 10:05 pm
Rocky Mountains use a 3/16 cable. The problem is most people assume, incorrectly, that Rocky Mountains used rods. Do your home work! Rocky Mountains were never designed to use a rod, nor did they have an extension on the lower portion of the brake pedal. The current edition of Rocky Mountains is a combination of 1926 style AC brakes, and Bennett brakes.
First Name: Dallas
Last Name: Landers
Post by Dallas Landers » Mon Jun 03, 2019 9:01 am
I have been following this thread because I have an original set of RM for my TT. Larry, how was the peddle set up without the extended peddle to hook to? I have instruction sheet from modern RM's. I have just the brake parts and no equalizer. Not to hijack OP but just gathering info.
Thanks Dallas
Tiger Tim
Last Name: Eckensviller
* REQUIRED* Type and Year of Model Ts owned: 1926 cut-off touring
Post by Tiger Tim » Mon Jun 03, 2019 10:48 am
IIRC it’s a metal sleeve that clamps to the pedal just below the floor, then I believe a short rod that terminates in a pulley near the U-joint. The rod has a turnbuckle in it and a bracket that keeps everything from flopping around. There’s a single cable to both brakes that runs in a “V” through that pulley.
Come to think of it, aren’t there similar rigs designed to make the rear drums into service brakes on late Ts?
Post by RajoRacer » Mon Jun 03, 2019 11:17 am
I'll get a photo of my original R.M pedal linkage later today & post it.
Post by RajoRacer » Mon Jun 03, 2019 8:57 pm
Here's what an original R.M. brake pedal clamp & linkage looks like.
First Name: Dallas
Last Name: Landers
Post by Dallas Landers » Mon Jun 03, 2019 9:20 pm
Thank you Steve. I think even I could make that.
Post by Original Smith » Sun Jun 09, 2019 12:58 am
Steve: I sure wish I had those parts you just posted. Those kind of parts probably got scrapped by the 100's because no one knew what they were for!
Tiger Tim
Post by Tiger Tim » Sun Jun 09, 2019 9:51 am
Not to commit someone else to a job but I’m sure a bunch of folks around here could whip up copies of those in their sleep.
Last Name: Wrenn
Post by TWrenn » Sun Jun 09, 2019 10:04 am
On this subject..and I'll also post in the classifieds if anyone has an RM set for sale or even A/C brakes please PM me. I plan on putting one or the other on my '25 Fordor. Thanks
Post by Original Smith » Mon Jun 10, 2019 12:53 am
I had the pleasure of seeing an original Rocky Mountain brake assembly on a TT rear end this weekend. What a pleasure1
