Carb Identification
Mike.aanonson
First Name: Michael
Last Name: Aanonson
Carb Identification
Post by Mike.aanonson » Tue Mar 05, 2024 7:33 pm
Trying to find info on this brass carb. Top looks like a Holley G, but fuel inlet looks like a Holley H1
Model T Mark
Last Name: Eyre
* REQUIRED* Type and Year of Model Ts owned: 1913 Touring 1914 Touring and Roadster 1915 Touring 1926 Roadster
Re: Carb Identification
Post by Model T Mark » Tue Mar 05, 2024 8:15 pm
1912 style Holley. One of three variations that ford used in 12.
Last Name: Tannehill
Board Member Since: 2002
Post by JTT3 » Tue Mar 05, 2024 8:48 pm
Holley H1, good carb once rebuilt (I suggest Corey Walker). You are missing a very expensive piece and that’s the fuel line pipe that forms the elbow at the male fitting on the bowl. Repairing those bowls,if you can, is a nightmare. Best John
Post by Allan » Tue Mar 05, 2024 10:18 pm
That's a later version of the Holley H1. The earlier one had just two screws on the top plate. This 3 screw version suffered less distortion and made the carbs easier to restore. I too need the stepped screw on which the float arm pivoted.
