A Modified VW Distributor Problem
J1MGOLDEN
Last Name: Golden
Post by J1MGOLDEN » Mon Mar 11, 2024 1:34 pm
A Texas T Distributor with a modified VW Distributor has modern spark plug wires of the fiberglass thread/graphite impregnated type.
The distributor has good bushings, new correct genuine Bosch Points, Capacitor, Rotor, and Distributor Cap, but no sparks reach the spark plugs.
Removing the coil wire from the distributor center and holding it near the engine produces a good spark.
Yet, no sparks get to the spark plugs.
This suggests there is a reason those spark plug wires are never used on a Model T and I have never seen them used.
Would anyone know the reason and likely problem with them?
Re: A Modified VW Distributor Problem
Post by TRDxB2 » Mon Mar 11, 2024 2:14 pm
Try to see if you get a spark from the coil wire to the distributor head. If not you need to a ground wire to the head.
Post by Mark Gregush » Mon Mar 11, 2024 3:27 pm
Or the points need to be cleaned. If the wires work in a "more" modern car, they should work fine for your setup. I have used them in battery point/coil setups before and don't recall them not working.
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Mon Mar 11, 2024 4:48 pm
If the spark is jumping thru the coil wire it should also jump thru the plug wires. Check that the center contact carbon brush did not fall out of the cap
Gene_French
First Name: Gene
Last Name: French
Board Member Since: 2014
Post by Gene_French » Mon Mar 11, 2024 6:17 pm
assuming the rotor is inplace , i would check to see if there is a carbon track burned thru the rotor and shorting to the distributor shaft ...Gene French
J1MGOLDEN
Last Name: Golden
Post by J1MGOLDEN » Mon Mar 11, 2024 6:23 pm
The orange distributor cap did have the small round brush jammed back into the cap, but it did not help to work it out.
That one did look like new but was not made by Bosch.
The one that replaced that one did have the Bosch name on it and part number on it has a spring-loaded center brush that hangs down almost half an inch.
Post by TRDxB2 » Mon Mar 11, 2024 7:10 pm
Think we need to regroup to understand what your working with. You description "A Texas T Distributor with a modified VW Distributor ....
The distributor has good bushings, new correct genuine Bosch Points, Capacitor, Rotor, and Distributor Cap,..."
Is this a clip on or front plate Texas T body to which someone has replaced their distributor with an original VW one. Trying to understand what was "modified". If it is an original VW what is the model number (should be stamped on the head)
Pictures always help
J1MGOLDEN
Last Name: Golden
Post by J1MGOLDEN » Mon Mar 11, 2024 9:19 pm
The apparent four VW 009 Series distributors were modified by removing the mechanical advance hidden under the plate that holds the points, and eliminates that function by changing the plate to let the rotor turn counter-clockwise, looking down from the top. A small arrow on the outside case suggests the rotor turns clockwise and it did.
Evidently, some of the changes may have been done for the VW vehicles, but I have no direct information.
Snyders has the points for sale and they are listed as an early set or a late set.
The early points are for the rotor that turns clockwise and the late points are for the rotor that turns counter-clockwise, as seen looking down from the top.
Post by RajoRacer » Mon Mar 11, 2024 9:31 pm
Most if not all of the early Bosch conversions used a "bell crank" unit w/double spark arms - I understand the TTP conversion utilized a reverse cut gear to change the rotor direction thus eliminating the 2 spark control arms.
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Mon Mar 11, 2024 11:01 pm
Rotate the distributor until the points just crack open and make sure the rotor is pointing to one of the cap terminals. If someone reversed the rotation of the original dist, the rotor may be pointing in no mans land.
t-time
Last Name: Bruto
* REQUIRED* Type and Year of Model Ts owned: 1914 speedster 1927 coupe
Post by t-time » Mon Mar 11, 2024 11:53 pm
The VW distributor is made to turn clockwise, the Texas T drive turn it counter clockwise so the points open while the rotor is between cap contact posts.
There have been many repros of the 009 distributor with variances, the one TTP uses has 3 mounting holes in the points plate that allow right or left hand points to be used depending on direction of rotation. If your distributor has 3 holes just put in the points that point the other direction, if not you would have to make new holes so the points mount 45 degrees from were they currently are so the points open when the rotor is aligned with one on the cap contact posts.
Post by TRDxB2 » Tue Mar 12, 2024 12:35 am
All that was stated was it was a "modified VW distributor" No idea if its for 6 or 12 volt either
Could be an 009 or 010 were both centrifugal advance . or something else
It very easy to get the wrong parts
No point guessing --- pictures and part numbers are needed
First Name: craig
Last Name: leach
Post by Craig Leach » Tue Mar 12, 2024 12:41 am
Hi James,
Staring from scratch, Has this unit worked in this application before? The issue that I find most often with your description is bad rotor. Bosch
VW rotors have a resistor for radio noise suppression this can fail and you will have spark from the coil & not to the plugs. This is a real pain
to diagnose because it may show good when testing & fail when running or starting. There is a Porsche rotor that does not have a resistor in it
but hard to find. I have found the resistor bad in new rotors so if you find this to be the issue buy & test a spare & keep it in the tool box.
If you have a spare you will most likely never need it but some one you know or meet on the road will love you for having one.
Post by Allan » Tue Mar 12, 2024 6:10 am
With any transplant, the patient is usually treated with immuno-supressants to avoid rejection issues. I have no idea what you use in this situation. :D
AndyClary
First Name: Andrew
Last Name: Clary
Post by AndyClary » Tue Mar 12, 2024 12:45 pm
Kevin, Gene and Dan are in the right direction. If it’s sparking then the points and coil are working. If it goes into the distributor it’s gotta come out. I have seen really poor cap alignment on aftermarket distributors.
Andy
RVA23T
Last Name: C
Post by RVA23T » Tue Mar 12, 2024 2:54 pm
An I-Timer and coils
J1MGOLDEN
Last Name: Golden
Post by J1MGOLDEN » Wed Mar 13, 2024 8:33 pm
Final Report!
A new set of proper yellow spark plug wires were installed today and now the engine starts right up and runs great!
Gen3AntiqueAuto
Last Name: Foye
* REQUIRED* Type and Year of Model Ts owned: 27 Fordor, 15 speedster (2), 23 touring, 26 fordor, 25 TT
Post by Gen3AntiqueAuto » Thu Mar 14, 2024 2:45 pm
TTP dist's are not 009 VW. I took a long hard look at one recently. Looks to me like they were made to order by the chinese. There is no advance in them, and they spin the wrong way.
Take a look: https://youtu.be/efjcjzGZjvs
I have one here for sale if anyone needs it. It's the exact one from the videos. Email me (card below) if you are interested.
Gen III Antique Auto - we do Model T Ford Restorations
You can have everything in life you want, if you will just help other people get what they want -Zig Z.
https://www.youtube.com/channel/UCeROBg ... pB-KImprjw
First Name: craig
Last Name: leach
Post by Craig Leach » Thu Mar 14, 2024 3:22 pm
Hi James,
I know several people running resistor plug wires. ( if you run a Pertronix electronic unit they say do not run solid wires they will destroy the
pick up) That a side did this ever run with the resistor wires??? Keeping in mind there is a resistor in the rotor & you had resistor wires ( double
the resistance value ) what are the chances that all four wires failed at the same time?? There is a chance that the rotor is starting to fail &
replacing the wires is just a Band-Aid on the issue. I'm thinking to be on the safe side have a extra rotor. You May want to also consider that the
coil is starting to fail and can not produce enough voltage to overcome the resistance of the rotor & wires.
Tim,
I think you will find that there are so many Chinese MFG's of these distributers that Bosch no longer see's a profit in making them for cars that
have been out of production for over 30 years.
J1MGOLDEN
Last Name: Golden
Post by J1MGOLDEN » Thu Mar 14, 2024 4:20 pm
Tim is correct about the Chinese VW distributor and that is what I was working on.
The pink plastic distributor cap is a give-away now.
The Texas T distributor on my 1926 Roadster has been on there for over 30 years and is a modified VW distributor like I mentioned.
There are four or more original VW distributors with several four letter groups that all end in 009 that are the ones used for all the early Texas T distributors.
The give-away for one of those is a small arrow on the case that points in a clock wise direction.
T
J1MGOLDEN
Last Name: Golden
Post by J1MGOLDEN » Thu Mar 14, 2024 4:40 pm
The VW Distributor arrow on the early original Distributor kits was correct to identify the Clockwise Rotation, if the advance rod had a toggle in the middle to reverse the direction of advancement.
Later distributors turned in the other or counter-clockwise direction to eliminate the toggle and a few small parts.
J1MGOLDEN
Last Name: Golden
Post by J1MGOLDEN » Sat Mar 16, 2024 1:48 pm
The distributor problem was a total lack of sparks all along.
Normally, a new set of points would fix the problem, that was wrong this time.
Today, the points were checked again and not hardly opening.
The max measured today was .004 and they are normally set to open at .018 which would be OK on a modified VW distributor.
This distributor was Made in China
, either with the proper lobes never there or almost totally worn off, which is not likely!
The bottom bushing was worn excessively, but the top bushing was hardly worn.
That shaft is not likely a sold separate repair item!
The 009 distributors are getting difficult to find and my last one is on that engine now!
J1MGOLDEN
Last Name: Golden
Post by J1MGOLDEN » Sun Mar 17, 2024 7:24 pm
Today, I installed my last spare, sometimes loaner Texas T VW Distributor and the T is running like new again!
