Odd T differential spider
Kenny Edmondson
First Name: Kenny
Last Name: Edmondson
* REQUIRED* Type and Year of Model Ts owned: 1923 Touring 1924 Roadster PU
Post by Kenny Edmondson » Fri Mar 15, 2024 1:12 pm
What is this T style differential spider for? No center hole for the axles…
RVA23T
Last Name: C
Re: Odd T differential spider
Post by RVA23T » Fri Mar 15, 2024 1:22 pm
Man I wish it was April 1 so I could say
"Japanese export differential with extra Ninja throwing star included."
Post by speedytinc » Fri Mar 15, 2024 1:28 pm
Fonzie says AAAAAAAAAAAAAA
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Fri Mar 15, 2024 1:44 pm
Perhaps a really early spyder? Kim Dobbins may know. Any chance it has DB on it. I know the really early spyder gears had bronze bushings in them.
Kenny Edmondson
First Name: Kenny
Post by Kenny Edmondson » Fri Mar 15, 2024 3:18 pm
Well it is a Model A spider. Never would have guessed that. Same exact size as a T only no hole… Thanks John.
RVA23T
Last Name: C
Post by RVA23T » Fri Mar 15, 2024 4:11 pm
so the A axles are retained by the carrier correct?
Post by Mark Gregush » Fri Mar 15, 2024 8:19 pm
And Model A spider gears are the same as T. Later they did add an oil hole, but fit and function, the same. Take some time to go through the 1928 Model T parts book, you will find a few parts that carry the A part numbers.
