Firing order
vping
First Name: Vincent
Last Name: Pina
Firing order
Post by vping » Sat Mar 16, 2024 7:46 pm
So I was looking at pictures on the cars for sale forum and noticed the firing order. I questioned it if was 1342 and was informed it's 1243.
So I took another look at my car and the picture below is what I have. I noticed the other cars #1 is where my #3 is. I did not wire the car and this could explain why it's potentially not running correctly. I had it running a few weeks ago, got it up to temp. Then I could not get it started.
Some history: Did some re-wiring of some bare wires, I have nice points spark and spark at every plug. I thought I was getting fuel but I think my needle is sticky so Lang's sent me a new set that arrived yesterday. (Under the weather so I couldn't get anything done today)
Any advice on my firing order is welcome.
vping
First Name: Vincent
Last Name: Pina
Re: Firing order
Post by vping » Sat Mar 16, 2024 7:49 pm
Additional info. Picture taken standing next to the passenger fender so #3 is closest to radiator.
First Name: Keith
Last Name: Townsend
Re: Firing order
Post by KWTownsend » Sat Mar 16, 2024 7:52 pm
The physical location of the wire on the distributor makes no difference. Unless there is a wire length issue. The only thing important is the firing order of 1-2-4-3.
vping
First Name: Vincent
Last Name: Pina
Re: Firing order
Post by vping » Sat Mar 16, 2024 8:20 pm
Gotcha. I have some wire swapping to do.
fschrope
First Name: Fred
Last Name: Schrope
* REQUIRED* Type and Year of Model Ts owned: 1923, 1926, 1927 TT's, 1918 cutoff touring, 1922 Coupe - original
Re: Firing order
Post by fschrope » Sat Mar 16, 2024 9:04 pm
Which direction does the distributor turn. Clockwise will give you 1243, counterclockwise will give you 1342. I have no idea which.
If they are wrong, I doubt it would run at all. If it did, it would be so bad that you certainly would know something was wrong. Or, I might kick the stuffin's out of you or the starter. I'd have to think about that though.
Another thought though, how old are you. Young folks don't know clockwise and counterclockwise. :D
Re: Firing order
Post by Norman Kling » Sat Mar 16, 2024 9:21 pm
Interesting the Model A is 1 3 4 2 but the T is 1 2 4 3. Just look to see which way the rotor turns when you turn the crank and put the wires in that order.
Re: Firing order
Post by RajoRacer » Sat Mar 16, 2024 10:22 pm
Model A is the same as a T, Norm.
Re: Firing order
Post by Norman Kling » Sun Mar 17, 2024 12:47 am
No it is not. I have had at least 13 of them and they are different.
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Re: Firing order
Post by Dan McEachern » Sun Mar 17, 2024 12:54 am
Ok, but....................
Joe Reid
First Name: Joe
Last Name: Reid
* REQUIRED* Type and Year of Model Ts owned: 1919 Coupe, 1920 Roadster, 1923 Touring, 1924 Roadster, 1913 Racer
Re: Firing order
Post by Joe Reid » Sun Mar 17, 2024 1:32 am
Didn’t we do this a couple of months back? 1, 2, 4, 3 is for T’s, A’s, B’s, 9N’s, 8N’s, Jubilee’s etc. Probably earlier to.
Joe Reid
First Name: Joe
Last Name: Reid
Re: Firing order
Post by Joe Reid » Sun Mar 17, 2024 3:11 am
Where is the rotor pointing when #1 is at top dead center?
Susanne
First Name: Susanne
Last Name: Rohner
Re: Firing order
Post by Susanne » Sun Mar 17, 2024 4:17 am
Toward the position on the cap where the wire going to the #1 plug is if the cap was on the distributor. I start with no wires, put #1 at TDC, look at where the dist. rotor is pointing, and that's where the wire to the #1 plug goes in the cap. Crank the motor 1/2 turn - now the rotor is pointing where #2 goes. Nother 1/2 crank, and it's pointing at #4, so the #4 wire goes there, then you do 3.
When you're setting up, I was told to pull the spark lever down 3 or so notches, so you have a retard setting while starting with it all the way up - I've had Distributor equipped T's snap back and try to bite me if you don't do that. Ouch.
Sounds silly, but different distributors set up differently... Sometimes the gears aren't indexed correctly, but this way your dizzy will still work.
Re: Firing order
Post by Jerry VanOoteghem » Sun Mar 17, 2024 7:55 am
That's not what Keith was suggesting to do.
Re: Firing order
Post by Jerry VanOoteghem » Sun Mar 17, 2024 8:09 am
The Model A Ford Club of America seems to think it's 1-2-4-3.
https://www.mafca.com/downloads/Seminar ... 0Janke.pdf
Last Name: Strange
Re: Firing order
Post by CudaMan » Sun Mar 17, 2024 12:53 pm
Page 2 of the attached .pdf file says 1,2,4,3:
2012 Hershey Distributors Alex Janke.pdf
(525.95 KiB) Downloaded 89 times
Re: Firing order
Post by Steve Jelf » Sun Mar 17, 2024 1:10 pm
Yes, 1, 2, 4, 3 is correct, whether you're using a timer or a disturbutor. Model A? Don't know much about those modern cars.
Re: Firing order
Post by Norman Kling » Sun Mar 17, 2024 6:15 pm
I was wrong! I guess I always counted clockwise when distributor cam turns counter clockwise! It's been 50 years since I sold the last one! It was sold by accident. I put an ad in the restorer for $3,000 which I didn't think anyone would pay that much for a Model A! I had some people from Southern California who looked it but didn't want to pay my price. Then someone from La Fayette La came out, looked at at it. Dolores said what will I drive tomorrow. I said, "its not sold yet". Immediately they pulled out the money and paid for it! I thought it would be too far to commute from Alpine to San Diego every day in it so I had bought a Dodge Dart which I thought would become a collector car, but sadly it did not. Mine was 6 cylinder and the collectors wanted the V8. I had it until my son drove it to a place called Dictionary hill in San Diego which went right down the hill about 10% grade. There was a cross street and the kids liked to go fast down the hill and get airborne when they crossed the other street. Unfortunately he broke the block right where it was mounted to the motor mount. It had also been T boned by a kid coming out of the parking lot at high school so one side was bent in. The car went to the junk yard!
vping
First Name: Vincent
Last Name: Pina
Re: Firing order
Post by vping » Sun Mar 17, 2024 8:01 pm
Didn't swap a thing and I was finally able to get it re-started. It runs great and there's still things to do.
Re: Firing order
Post by Norman Kling » Sun Mar 17, 2024 8:34 pm
Good I'm happy for you that you got it started.
vping
First Name: Vincent
Last Name: Pina
Re: Firing order
Post by vping » Mon Mar 18, 2024 2:47 pm
Agreed. It was a duh moment. I did get it running and it runs very well.
Re: Firing order
Post by Jerry VanOoteghem » Mon Mar 18, 2024 2:49 pm
Then that's what counts!!
