trouble shooting weak ignition spark !!! Help
Dave_Kriegel
First Name: David
Last Name: Kriegel
* REQUIRED* Type and Year of Model Ts owned: 1927 1926
Post by Dave_Kriegel » Mon Jun 03, 2019 8:24 am
Well I have been working on a non starter 1917 for a month Zero compression, no spark Now with valve and ring job, new wiring, rebuilt coils still no start I have narrowed it down to a very weak visible spark when I lay the plugs on the block and rotate the cylinders into firing order . I have read on the forum years past that a weak spark visible on a plug OUTSIDE the block will result in no spark when the spark plug is chambered and under pressure. I am using modern F 11 plugs new, set at 032 I have strong coil noise New spark plug wires, The only thing I may think of since this is a non starter car is I used 12 gauge wire for both the 12 volt :?: :!: battery ground and running up to the ignition switch Could this thin wire not carry enough amperage ?? Any ideas ?
rickd
First Name: Rick
Last Name: Duquette
* REQUIRED* Type and Year of Model Ts owned: 1913 Touring, 1914 Touring, 1925 Touring, 1927 PU, 1955 T Bird, 69 Shelby GT 350
Re: trouble shooting weak ignition spark !!! Help
Post by rickd » Mon Jun 03, 2019 8:34 am
What kind of shape is your coil box and switch in? Maybe some carbon tracking or some other kind of resistance holding back a decent spark?
Hal
First Name: Hal
Last Name: Davis
* REQUIRED* Type and Year of Model Ts owned: '22 TT Stake Bed, '18 Touring (Hers)
Post by Hal » Mon Jun 03, 2019 12:16 pm
Professionally rebuilt coils or .......?
Post by Scott_Conger » Mon Jun 03, 2019 12:38 pm
Hal's question as well, plus, are your spark plug wires copper conductors soldered to their terminations, or are they modern carbon-filled wires?
It's Bill
First Name: Bill
Last Name: Hoffer
Post by It's Bill » Tue Jun 04, 2019 7:37 am
I suspect the gap. My antiques do well with about a .022 gap. Might be worth a try. Hope this helps, and good luck! Cheers, Bill
Charlie B in N.J.
First Name: CHARLIE
Last Name: BRANCA
Board Member Since: 2010
Post by Charlie B in N.J. » Tue Jun 04, 2019 12:31 pm
Not sure about the wire size as it doesn't take much to fire the coils but, as mentioned earlier, "rebuilt coils" ? Done by who and were they properly set up on a HCCT or similar unit? If they weren't it's probably a big part of your spark problem. It simply MUST be done. No question. If they were done correctly run a larger size temporary wire to the coil box and check for a difference. Disconnect the coil box wire first though. A poor ground is another thing to check as in a clean timer. It's as bad as low voltage. I's also try a smaller plug gap. 0.30 for instance.
