muncie
tdump
First Name: Mack
Last Name: Cole
muncie
Post by tdump » Tue Mar 19, 2024 9:18 pm
I ask about this and it is really to heavy to try to ship but i think it is a good deal.
http://www.antiquetruckclub.org/forum/? ... 1338114665
Last Name: Tannehill
Board Member Since: 2002
Re: muncie
Post by JTT3 » Tue Mar 19, 2024 9:32 pm
That’s a great price even if shipping was $200, it’s a 3 speed plus reverse
Re: muncie
Post by Wayne Sheldon » Wed Mar 20, 2024 1:33 am
I agree with JTT3 ! That is the heavy or big case Muncie, and most likely has under, direct, overdrive, and reverse. I had one in my first speedster (they do fit and were sold for use in both Ts and TTs! Don't fall into that "Truck" Muncie Bologna.
If the gears are in reasonably good condition, they are great for any model T. I would dearly love to have another one if I could afford it.
If you are worried about the weight? They are not that much heavier. So stop eating ice cream.
First Name: craig
Last Name: leach
Re: muncie
Post by Craig Leach » Wed Mar 20, 2024 2:43 am
Hi Mack,
I very much like the Muncie Aux. transmissions, they are cheap to rebuild and dependable. That one is better suited for a truck. @ that price
& if shipping is $200 it would be cheaper than most I have purchased with shipping. I have one in my fire truck ( second one not because the
first one failed ) it's still good but I wanted the lower overdrive ratio. Input & output couplings are hard to find so look to get them anytime
you look @ getting a Muncie.
vwmarc
First Name: Marc
Last Name: Engel
* REQUIRED* Type and Year of Model Ts owned: 1915 Pick Up
Re: muncie
Post by vwmarc » Wed Mar 20, 2024 2:18 pm
Thank you so much for posting this! I just called him and it turns out Steve lives 20 minutes away from me. He wants me to bring a 4th main cap to make sure it will fit a Model T and if it does then it is going home with me.
Erik Barrett
First Name: Erik
Last Name: Barrett
Re: muncie
Post by Erik Barrett » Wed Mar 20, 2024 2:59 pm
Be aware that Muncie transmissions require a special u joint and adapter coupling that are often missing. They scream like a banshee in overdrive.
vwmarc
First Name: Marc
Last Name: Engel
Re: muncie
Post by vwmarc » Wed Mar 20, 2024 4:33 pm
Thanks Erik! I already have the other bits and pieces plus a rare original Muncie brace that goes under it to give added support.
tdump
First Name: Mack
Last Name: Cole
Re: muncie
Post by tdump » Wed Mar 20, 2024 5:20 pm
glad I could help.
If I had been better off money wise, I might a ask about shipping but I have already gone far enough along on my speedster I don't want to undo a bunch of stuff. I waited a few years thinking I would find 1 of these before i really did alot to it as I would have extended the chassis instead of cutting the driveshaft.
Karl Von Neumann
First Name: Karl
Last Name: VonNeumann
Board Member Since: 2022
Re: muncie
Post by Karl Von Neumann » Thu Mar 21, 2024 12:53 pm
I've got a parts Muncie I tried to give it away and couldn't get a guy to take it
YellowTRacer
First Name: Ed
Last Name: Archer
Board Member Since: 2009
Re: muncie
Post by YellowTRacer » Thu Mar 21, 2024 4:30 pm
Gotta disagree with Eric on the screaming. If they're in good shape, no screaming in overdrive.
Ed aka #4
First Name: craig
Last Name: leach
Re: muncie
Post by Craig Leach » Sat Mar 23, 2024 2:16 am
I'm with Ed, one in good shape is no noisier than a Warford, but if worn Eric is correct don't drive by a cemetery in over or under it may wake
the dead. Karl do you still have the parts Muncie? I have one that could use some help.
Susanne
First Name: Susanne
Last Name: Rohner
Re: muncie
Post by Susanne » Sun Mar 24, 2024 10:30 am
Me as well... for the short time I had a muncie it was perhaps a transmission second only to Ruckstell, if it's screaming, you have an interference, bearing, or other problem. Those were perhaps one of the BEST aftermarket transmissions for a T that were built, That's why they're so desirable.
If yours is howling in OD, you need to take it to someone who knows gears and can make it right. Because they aren't supposed to do that (especially in OD).
Re: muncie
Post by Wayne Sheldon » Mon Mar 25, 2024 1:28 am
I have had two good (and still have one junk?) Muncies for model Ts. Both were quiet in all gears. Loved them! The Warford I ran for several years was also good, but a little noisier.
tmodeldriver
Last Name: Hester
* REQUIRED* Type and Year of Model Ts owned: 26 touring, 27 touring, 22 TT
Re: muncie
Post by tmodeldriver » Mon Mar 25, 2024 10:23 am
The Muncie in my TT only whines in overdrive during deceleration. Pretty quietly and a little louder when braking. I kinda like it.
First Name: craig
Last Name: leach
Re: muncie
Post by Craig Leach » Mon Mar 25, 2024 11:48 am
Spur gears are inherently noisy especially @ faster speeds. If they are worn or loose on the main or counter shafts they tend to vibrate &
that creates harmonics that are very audible. We are working with 100 year old transmissions. Reality is there is no good way to tighten up
these tolerances. Heavier gear oil may help with noise but they can also impede adequate lubrication in some places. I have driven model
A's that where noisy in first & second. A Hale slit shaft PTO in a fire truck @ 15+ years old sounds like a B-29 taking off under load pumping
2,000 GPM.
Karl Von Neumann
First Name: Karl
Re: muncie
Post by Karl Von Neumann » Thu Mar 28, 2024 12:39 pm
I'll shoot you an email with some pics
StevenS
First Name: Steven
Last Name: Sebaugh
* REQUIRED* Type and Year of Model Ts owned: 1924 Touring, 1924 TT Truck
Re: muncie
Post by StevenS » Thu Mar 28, 2024 1:09 pm
This should help too. Scroll down to see/download the Muncie Transmission Manual
https://www.mtfca.com/phpBB3/viewtopic.php?t=25862
1924 Model T Touring
1924 Model TT Truck
1928 Graham-Paige model 619
1930 Model A Phaeton
Re: muncie
Post by JTT3 » Thu Mar 28, 2024 4:12 pm
Well Mark did you end up with the Muncie?
vwmarc
First Name: Marc
Last Name: Engel
Re: muncie
Post by vwmarc » Fri Mar 29, 2024 10:11 pm
Yes. It seems to be in good shape and shifts through the gears fine. I will open it up eventually and go through it first before using. I am one of those people that does not know how to resize photos to fit here so I cannot post pictures.
