What can I use for the sealer for the 27 sediment bowl
NY John T
Last Name: Killelea
Post by NY John T » Mon Mar 18, 2024 2:45 pm
Hi all. What can I use for the sealer for the sediment bowl? Will Permitex #2 work, or is there something better? Thanks, John
Re: What can I use for the sealer for the 27 sediment bowl
Post by speedytinc » Mon Mar 18, 2024 2:53 pm
What are you "sealing"
Permatex on threads
Lead gasket on the drain fitting.
Graphite string packing on the valve stem.
NY John T
Last Name: Killelea
Post by NY John T » Mon Mar 18, 2024 5:01 pm
I need to install the sediment bowl to the cowl gas tank, thanks
Post by TRDxB2 » Mon Mar 18, 2024 5:12 pm
Do not use Teflon tape or sealant for "gas" valves (that's natural gas)
If it for gasoline make sure its soft setting and will not harden. There are lots of discussion on how to get the sediment bulb off when stuck.
Haven't used it but others have
Last Name: Patrick
Post by jiminbartow » Mon Mar 18, 2024 8:26 pm
Are you installing an original cast iron Ford script sediment bulb/valve? Yellow Teflon tape is what you use for gasoline fittings as long as the threads are sharp and not damaged or pitted, otherwise, use the pipe dope. Just be sure it will stand up to gasoline. For a sure seal, feel free to use both. Jim Patrick
vping
First Name: Vincent
Last Name: Pina
Post by vping » Mon Mar 18, 2024 8:39 pm
I used blue hylomar. No leaks to report.
NY John T
Last Name: Killelea
Post by NY John T » Mon Mar 18, 2024 9:02 pm
Yes it is an original cast iron bowl
Post by Mark Gregush » Wed Mar 20, 2024 2:30 am
This stuff if pretty good, I have used it more then a few times and seems to prevent leaks on gas fittings, along with being rated for that application;
https://www.summitracing.com/parts/ptx-56521?rrec=true
Last Name: Patrick
Post by jiminbartow » Wed Mar 20, 2024 9:46 am
Mark. I read all the information the Permatex link and cannot see where it is specifically for gasoline. Are you sure it will stand up to gasoline? Knowing me, I probably missed something LOL. Respectfully submitted, Jim Patrick
Post by speedytinc » Wed Mar 20, 2024 10:26 am
Read the specifications. It does mention fuel fittings.
Post by TRDxB2 » Wed Mar 20, 2024 10:52 am
The yellow. "gas" rape is for natural gas not gasoline
Post by Mark Gregush » Wed Mar 20, 2024 10:55 am
For John;
* Contains PTFE
* OEM-specified
* Standard applications: stainless steel fittings, head bolts into through holes, oil psi sending units/sensors, oil and coolant lines, intake manifold switches, rear axle fill plug, fuel fittings
* Motorcycle applications: timing hole plug and oil hose fittings
* Heavy-duty applications include drain plugs, all tapered fittings
aDave
First Name: David
Last Name: Dufault
Post by aDave » Wed Mar 20, 2024 11:44 am
Highly recommended:
https://www.modeltford.com/item/2902LUB.aspx
Expensive, but one tube will outlast you and have enough left over for your GRANDchildren.
sloppy threads on the tank fitting? a couple of turns with cotton (NOT NYLON) dental floss will fill the voids....keep away from thread end.
Last Name: Wrenn
Post by TWrenn » Wed Mar 20, 2024 12:28 pm
Might as well toss my 2 cents in! :lol:
This stuff is great! Easy applicator cap too!
Definitely for gasoline and many other fuels.
Post by TRDxB2 » Wed Mar 20, 2024 12:47 pm
* Contains PTFE
* OEM-specified
I agree that PTFE tape can be used for gasoline. BUT I don't trust the color of the tape to indicate its overall use (too much stuff made overseas :cry: ) prefer that it states what its made of Material Polytetrafluoroethylene or just PTFE
Oatey is available most everywhere & looks like I'm headed for Harbor Freight Today
Post by Mark Gregush » Wed Mar 20, 2024 10:09 pm
I was replying to Johns post about the Permatex sealer not the tape post.
600wt
First Name: Bill
Last Name: Robinson
* REQUIRED* Type and Year of Model Ts owned: 2 each 1927 Tudors (Twins), 1926 Roadster Pickup, 1925 Touring Car, 1921 Depot Hack
Post by 600wt » Wed Mar 20, 2024 10:20 pm
I'm with Dave Dufault on his choice of EZ TURN Lubricant for aircraft. It's Fuel resistant. I've had fuel shut-off valves that would drip constantly. After taking the valve apart and putting a small amt on the moving parts the leak stops and so far no re-do's on any of my T's. On carb sediment bowls, I will apply a very small amount (be stingy) around the lip where the bowl mates and so far no leaks.
EZ Turn Lubricant.jpg (14.04 KiB) Viewed 2388 times
