1926 Fordoor
Tinner12
Topic author - Posts: 144
- First Name: Vernon
- Last Name: Enis
- * REQUIRED* Type and Year of Model Ts owned: 1917 and 1924 touring,1926 4 door
- Board Member Since: 2011
1926 Fordoor
can someone give me a diagram of the wiring for the dome light on me 4dor. I have the dome light and the switch is on the post but I don;'nt know where the wires go
Re: 1926 Fordoor
Here’s an earlier post from the 2008 forum that has all you need for the wiring information for the dome light. http://www.mtfca.com/discus/messages/50 ... 1226178064
In the comments there are suggestions where to run the hot wire and there also might be something in the Ford service manual for the improved 26-27 cars.
Tinner12
- Last Name: Enis
Re: 1926 Fordoor
That is what I needed . Thankyou John
Re: 1926 Fordoor
If you notice the diagram doesn’t show which terminal of the dash main switch the wire goes to or maybe I didn’t see it but hope the earlier post will guide you. Good luck!
