WTB Regan Brake Switch
Tmooreheadf
Last Name: Moorehead
* REQUIRED* Type and Year of Model Ts owned: 24 Touring, 25 Coupe,
Post by Tmooreheadf » Mon Mar 25, 2024 1:26 pm
Does anyone have a John Regan brake switch they don’t need and may want to sell? My switch has gone south ( hogs head mounted style) and the Regan ones are not available at this time. PM me if you have one!
Tom
Re: WTB Regan Brake Switch
Post by Steve Jelf » Mon Mar 25, 2024 2:20 pm
It's not difficult to make your own switch. 1: sheet metal scraps to make a "body" and lever. 2: spring attached to the pedal shaft and the lever. 3: The least expensive push button temporary switch from the hardware store. When you step on the pedal, the spring pulls the lever against the push button to turn on the brake lights.
Home made control panel. The left blue light is the brake light indicator.
