TT Express Bed Floor
mtntee20
First Name: Terry & Sharon
Last Name: Miller
Post by mtntee20 » Tue Apr 02, 2024 4:39 pm
I am in need of some help. I want to replace the sheet of plywood the P.O. used for the floor of a steel TT Express bed/box. I believe there are 5 steel rub strips over the seams between 7 floor boards, 2 steel side strips for between the outer 2 boards and the steel box, and 1 steel strip across the back end at the tail gate to cover the 7 board ends.
Lang's sells the 5 steel rub strips and a hardware package for a Pick Up box (bolts, nuts, clips, and washers). I looked in the Encyclopedia, the Vowell Art Drawings, and on this forum, with no Luck.
Does anyone have an interior photo of an express bed floor? I need to verify my assumptions and count the number of bolts needed.
Thank you for reading this and for posting a photo if you have one.
Good Luck,
Terry
Re: TT Express Bed Floor
Post by DanTreace » Tue Apr 02, 2024 5:55 pm
Here's a few TT beds showing the bed strips, could be 5 is correct. These are longer than the pickup bed strips of course.
20120327131446 (480x360).jpg (136.89 KiB) Viewed 2218 times
20120327131403 (500x375) (490x368) (480x360).jpg (142.82 KiB) Viewed 2218 times
Post by RajoRacer » Tue Apr 02, 2024 6:03 pm
I'll check the TT book but I don't believe the Express bed & Flatbed use the same wood.
mtntee20
Last Name: Miller
Post by mtntee20 » Tue Apr 02, 2024 6:34 pm
Steve, Thank You. I believe the flat/stake bed is wider in the floor/deck as the express has the curved lower corners where the sides meet the floor. The lengths may be the same though, and the hardware should be the same or close to it. I don't have a TT book to check.
rwephill
Last Name: Evans
* REQUIRED* Type and Year of Model Ts owned: 1925 TT C-Cab
Post by rwephill » Tue Apr 02, 2024 7:40 pm
Not my truck, but is this what you are looking for?
“You don’t have to go fast… you just have to go.”
mtntee20
Last Name: Miller
Post by mtntee20 » Tue Apr 02, 2024 8:13 pm
Thank You Robert. That sure helps. Is this photo the same as your TT? I hope mine comes out as nice as the one in the photo.
ClaytonPaddison
First Name: Clayton
Last Name: Paddison
* REQUIRED* Type and Year of Model Ts owned: 1919 Depot Hack, 1924 TT Truck, 1927 Roadster
Post by ClaytonPaddison » Tue Apr 02, 2024 8:32 pm
Not to derail the current convo, but does anyone know if the TT express box side panels are re-popped? I ask because I really want to build up an 8ft Express for my '24 TT.
I have two RPU boxes I can join in the middle and make one, but it would be nice to start with the right sides at least.
Clayton Paddison "Mr. Model T"
1908 Model S Runabout
1919 Depot Hack
1924 TT 1-Ton
1927 Roadster "Gowjob"
Post by RajoRacer » Tue Apr 02, 2024 9:35 pm
Not that I've heard of Clayton. My Gramps' C-Cab express had a rotten floor so one of my Dad's mechanic's replaced it with ribbed steel plate - hell for stout but added a bit of weight !
Burger in Spokane
First Name: Brent
Last Name: Burger
Board Member Since: 2014
Post by Burger in Spokane » Wed Apr 03, 2024 1:32 am
My flatbed appears to be a well worn, but unmolested original. The
plank's grain looks to be ash ? I gave the thirsty wood a big drink of
mineral spirits and linseed oil .... a proper vintage treatment for rot
and weather resistance, about 5 yeats ago. Still holding up nicely. No
cutesy "pretty" wood for this work truck ! Photo too large to load, sorry.
rwephill
Last Name: Evans
Post by rwephill » Fri Apr 05, 2024 12:35 pm
I wish that was my bed. My truck came off a farm without any bed. I am building a wooden grain/express bed for it.
