Brass plugs in car. Passageways
NY John T
Last Name: Killelea
Post by NY John T » Thu Apr 11, 2024 10:34 pm
Hi all,
What suggestions do you all have for replacing the small brass plugs that seal the carb passageways? They're made of brass originally, I believe. Can I use heavy copper copper wire, or does it have to be brass? Thanks for your help.
John
Re: Brass plugs in car. Passageways
Post by TRDxB2 » Thu Apr 11, 2024 10:49 pm
Hi all,
John
Stan Howe suggested using set screws for the next time https://www.mtfca.com/discus/messages/1 ... 1279536155
Last Name: Hatch
Post by Dan Hatch » Fri Apr 12, 2024 6:33 am
Just be sure you don’t thread the screw in so far as to block the passage way.
Mark Nunn
Last Name: Nunn
Post by Mark Nunn » Fri Apr 12, 2024 7:55 am
I had brass screws on a shelf that worked.
jab35
Last Name: Bartsch
Post by jab35 » Fri Apr 12, 2024 8:33 am
Copper wire of appropriate gage would be fine, many use brass filler rod. I've used brass rod 'tinned' with solder to insure a tighter fit.
Post by Steve Jelf » Fri Apr 12, 2024 9:46 am
I've had no trouble using Uncle Stan's method.
