Anyone seen these ?????
Post by RajoRacer » Tue Apr 09, 2024 2:21 pm
Working on a Ruckstell out of a '15 Touring from the Lake Tahoe area many years ago - anyone recognize this type of outboard axle bearing ? The p.s. has what appears to be "knock-off" tabs across from each other - not so on the Ruckstell half ? Federal # FS88508 on the outer carrier.
Also: how not to bush a #160 housing !
Re: Anyone seen these ?????
Post by RajoRacer » Tue Apr 09, 2024 10:15 pm
To add to the mystery: both housings (later type) had both backing plates replaced with '15 - '16 smoothies - I'm assuming to participate in California HCCA festivities ! Both housings take the later open bolt d.s. spool & the fill hole is below centerline.
None of you California Folks remember any bearing conversions like this ????????
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Tue Apr 09, 2024 10:34 pm
Not me, but folks do some strange things with the thought of "making it better".
Post by RajoRacer » Wed Apr 10, 2024 10:31 am
Thanks Dan - I figured you might have seen something like this ! I'd sure like to know how they might be removed !
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Wed Apr 10, 2024 9:24 pm
HEY!!! I resemble that remark! :lol:
Hap_Tucker
First Name: Hap
Last Name: Tucker
Post by Hap_Tucker » Fri Apr 12, 2024 3:47 pm
Steve,
Minor comment. It appears thta Ford of Canada continued the smooth backing plates into 1920 and possibly later. Ref posting from long ago but found one by Wayne Sheldon at: https://www.mtfca.com/discus/messages/5 ... 1459684789 which says:
"Canadian production started using the low fill in 1915, fully three years before USA production, but continued the smooth backing plates at least until 1920 fully five years later."
I think it would be more likely that they used a Canadian rear axle rather than replacing the backing plates. Although they could have done the replacement.
Thanks Wayne & Steve.
Respectfully submitted,
Hap l9l5 cut off
Post by RajoRacer » Fri Apr 12, 2024 4:20 pm
Appreciate the comments Hap - supposed history of this '15 Touring was it was one of the xxx number built during the 1915 San Francisco Expo ! I'll check the housings a bit closer BUT they both take the later open spool & it's a later type torque tube so I'm assuming they were "modified".
