Question on the I timer
Will
Topic author - Posts: 188
- First Name: Will
- Last Name: Copeland
- * REQUIRED* Type and Year of Model Ts owned: 1915, 1919, 1923 TT
Question, Do you still need to retard the timing lever ATC on the I timer to start the car or does the timer do that on its own? Thank you.
As Tom Sellick told Marston in the movie Quigley Down Under, I told you I dont have much use for handguns, I never said I didn't know how to use them!
Bill Anziani
- First Name: Bill
- Last Name: Anziani
- * REQUIRED* Type and Year of Model Ts owned: 1924 Coupe
Re: Question on the I timer
You need to retard it, just like the original timer.
- Last Name: Hjortnaes
Then once it has started you advance it just like any other timer
