Period correct shocks
Topic author - Posts: 159
- First Name: Will
- Last Name: Copeland
- * REQUIRED* Type and Year of Model Ts owned: 1915, 1919, 1923 TT
What rear period correct shocks will work with AC brakes?
As Tom Sellick told Marston in the movie Quigley Down Under, I told you I dont have much use for handguns, I never said I didn't know how to use them!
- First Name: Terry
- Last Name: Woods
Re: Period correct shocks
Don't have your answer, but I know that there are some prone to breakage that should be avoided.
The issue with almost all aftermarket rear shocks have with accessory brakes (AC, RM etc) is that their perch doesn't clear the additional thickness of the drum. Snubbers are a possibility as are friction shocks OR have a rear perch made to clear.
I was fortunate to have some made for Hassler shocks as my project unfolded I wasn't sure if I was going to use them. Someone was looking for them and the "professional" maker wasn't ready to make another set, so I sold mine
but the idea should work for others
Have seen Hassler Pan Cake rear shocks clear a set of small drum outside brake, as there is some space above the brake drum.
Would think AC brakes over the factory small drums would be ok with Hassler Shocks.
Regular Hassler 'Bee Hive"
1924 and later 'Pan Cake' Hassler
- First Name: craig
- Last Name: leach
Hi Will,
Speedway Motors sells a single arm Truffault-Hartford style friction shock # 5606021 & some Model A style dog bone connectors & balls.
They can be attached to the rear crossmember & either to the shackle or axle putting them out of the way. Examples of these can be
scene on some speedsters on line. See NWVS thumb nail gallery pics. I have seen these on several touring cars also.
Craig.
Craig.
- First Name: Val
- Last Name: Soupios
I run Gabriel snubbers on my '22 Centerdoor.
- First Name: Haydon
- Last Name: Rowe
- * REQUIRED* Type and Year of Model Ts owned: 1924 Roadster Pickup, 1919 TT, 1913 Raceabout, 1912 Tourer
I don't know much about them, but was given these Hartford branded units, and assume they fit a T?
What I thought looked promising was that they don't sit over top of the drum like the Hasslers do in the top of the picture (or as per Dan's pictures) which I always thought would interfere with the AC bands.-
- First Name: warwick
- Last Name: preval
- * REQUIRED* Type and Year of Model Ts owned: 25 tr 22 coupe
- Board Member Since: 2014
Hello Dan i wonder if you could post a photo from the front view of that AC brakes & the Hasslers set up in your photos please as i would like to run some thing similar cheers Warwick.
