Coil hardware question
Jim11787
First Name: Jim
Last Name: Sarc
Board Member Since: 2023
Post by Jim11787 » Fri Apr 26, 2024 9:48 am
When replacing the coil top hardware can someone tell me where the 2 fiber washers go in the assembly process? The old coil I disassembled did not have them. I assume they are insulating washers.
Moxie26
Last Name: Jablonski
Re: Coil hardware question
Post by Moxie26 » Fri Apr 26, 2024 12:38 pm
Are you referring to the metal top coil, or the wood top coil?
For wood top coil
For wood top coil
For Metal top coil
For Metal top coil
Post by Mark Gregush » Fri Apr 26, 2024 3:13 pm
The two fiber washers are used under and over the bridge at the adjustment screw. I generally only use one under it.
Jim11787
First Name: Jim
Last Name: Sarc
Post by Jim11787 » Fri Apr 26, 2024 4:12 pm
Thanks Mark. That’s what I thought.
Ron Patterson
Post by Ron Patterson » Sat Apr 27, 2024 11:43 am
This Ford diagram depicts the details for what and where point mouning hardware should be installed on the Williams KW Ford ignition coil.
Coil Sketch SK-2202.pdf
(1.24 MiB) Downloaded 74 times
Ron Patterson
Post by Ron Patterson » Sat Apr 27, 2024 11:44 am
(1.24 MiB) Downloaded 182 times
Jim11787
First Name: Jim
Last Name: Sarc
Post by Jim11787 » Sat Apr 27, 2024 1:12 pm
Thank you Ron.
Chris Barker
First Name: Chris
Last Name: Barker
Post by Chris Barker » Sat Apr 27, 2024 1:20 pm
I agree with Mark; I find that the coil is best set up with just the fibre washer under the contact plate, above the coil spring.
And then TWO nuts above, locked.
Ron Patterson
Post by Ron Patterson » Sat Apr 27, 2024 2:13 pm
I got this sketch out of JPG format so it is easier to print.
