Period correct shocks
Will
First Name: Will
Last Name: Copeland
* REQUIRED* Type and Year of Model Ts owned: 1915, 1919, 1923 TT
Post by Will » Thu Apr 25, 2024 6:39 pm
What rear period correct shocks will work with AC brakes?
As Tom Sellick told Marston in the movie Quigley Down Under, I told you I dont have much use for handguns, I never said I didn't know how to use them!
ModelTWoods
First Name: Terry
Last Name: Woods
Re: Period correct shocks
Post by ModelTWoods » Thu Apr 25, 2024 8:28 pm
Don't have your answer, but I know that there are some prone to breakage that should be avoided.
Post by TRDxB2 » Thu Apr 25, 2024 9:33 pm
The issue with almost all aftermarket rear shocks have with accessory brakes (AC, RM etc) is that their perch doesn't clear the additional thickness of the drum. Snubbers are a possibility as are friction shocks OR have a rear perch made to clear.
I was fortunate to have some made for Hassler shocks as my project unfolded I wasn't sure if I was going to use them. Someone was looking for them and the "professional" maker wasn't ready to make another set, so I sold mine :evil: but the idea should work for others
Post by DanTreace » Fri Apr 26, 2024 10:48 am
Have seen Hassler Pan Cake rear shocks clear a set of small drum outside brake, as there is some space above the brake drum.
Would think AC brakes over the factory small drums would be ok with Hassler Shocks.
hass size.jpg (97.84 KiB) Viewed 1574 times
Regular Hassler 'Bee Hive"
IMG_0088 (600x450) (595x446) (2).jpg (142.48 KiB) Viewed 1574 times
1924 and later 'Pan Cake' Hassler
First Name: craig
Last Name: leach
Post by Craig Leach » Fri Apr 26, 2024 10:59 am
Hi Will,
Speedway Motors sells a single arm Truffault-Hartford style friction shock # 5606021 & some Model A style dog bone connectors & balls.
They can be attached to the rear crossmember & either to the shackle or axle putting them out of the way. Examples of these can be
scene on some speedsters on line. See NWVS thumb nail gallery pics. I have seen these on several touring cars also.
Russ T Fender
First Name: Val
Last Name: Soupios
Post by Russ T Fender » Fri Apr 26, 2024 9:08 pm
I run Gabriel snubbers on my '22 Centerdoor.
haydonr
First Name: Haydon
Last Name: Rowe
* REQUIRED* Type and Year of Model Ts owned: 1924 Roadster Pickup, 1919 TT, 1913 Raceabout, 1912 Tourer
Post by haydonr » Sat Apr 27, 2024 5:40 am
I don't know much about them, but was given these Hartford branded units, and assume they fit a T?
What I thought looked promising was that they don't sit over top of the drum like the Hasslers do in the top of the picture (or as per Dan's pictures) which I always thought would interfere with the AC bands.
warwick_preval
First Name: warwick
Last Name: preval
* REQUIRED* Type and Year of Model Ts owned: 25 tr 22 coupe
Board Member Since: 2014
Post by warwick_preval » Mon May 13, 2024 9:36 am
Hello Dan i wonder if you could post a photo from the front view of that AC brakes & the Hasslers set up in your photos please as i would like to run some thing similar cheers Warwick.
