Bushings, bushings, bushings
vping
First Name: Vincent
Last Name: Pina
Post by vping » Sat Apr 27, 2024 1:42 pm
See pic below. Other than the T bushes, can someone share the bushing part #s?
Before I purchase new, what the the tolerances? There's a little play but is there a numerical spec I can check?
Re: Bushings, bushings, bushings
Post by RajoRacer » Sat Apr 27, 2024 2:21 pm
Spindle bushings, spindle arm bushings, spring perch & spring eye bushings - they're in the parts catalogs under those names. You only want a couple thousands clearance for motor oil.
Post by Mark Gregush » Sat Apr 27, 2024 9:45 pm
After installing, they will need to be reamed to fit. The face of the spindle bushing may need to be faced. If you don't have a copy, while you are placing the order, get the Model T Service (The black book) so you know what needs to be done.
Post by Allan » Sat Apr 27, 2024 10:31 pm
You don't need spindle arm bushes if you are replacing King pin bushes. Used kingpin bushes are the same external diameter. You can drill them and ream them to the new tie rod end bolts. You can even leave some of the T head to work as a thrust face to take the weight of the tie rod and compensate for wear in the tie rod end yokes.
vping
First Name: Vincent
Last Name: Pina
Post by vping » Sun Apr 28, 2024 7:48 am
Not exactly so I'll need to read the book.
Post by TRDxB2 » Sun Apr 28, 2024 12:13 pm
So use your old spindle bushings?
vping
First Name: Vincent
Last Name: Pina
Post by vping » Sun Apr 28, 2024 6:32 pm
Awesome, awesome. Thanks. That will be very helpful. I've got a king pin reamer for my MGB and am familiar with how to dial it in. I think I should be able to do the bushings needed on the T.
vping
First Name: Vincent
Last Name: Pina
Post by vping » Sun Apr 28, 2024 6:54 pm
Sorry, I still cannot find the spring perch bushings.
Post by RajoRacer » Sun Apr 28, 2024 7:10 pm
Post by Mark Gregush » Sun Apr 28, 2024 10:49 pm
For the shackle bushings, you might consider getting the brass ones. They cost a bit more, but with the cost of new shackles, worn brass is cheaper to replace then the whole thing. ;)
