Take-Apart Spark plugs
jwrightjr
Last Name: Wright
* REQUIRED* Type and Year of Model Ts owned: 1922 Touring, 1925 Roadster
Post by jwrightjr » Sun Apr 28, 2024 6:18 pm
I have become the custodian of probably a couple hundred vintage spark plugs. I actually think they are a bit fascinating because of how many different companies had their versions of the same thing. I was looking through them today and decided to take (I should say attempt) a few apart to see if I could clean them up. Some of them look like they were part of an archeological dig but a little time on a wire wheel, torch and Kroil quenching I did get a few apart. Not much to go wrong with them once the carbon is cleaned out and no obvious porcelain issues. I cleaned up 4 champion X and bench tested them successfully. Decided to check them under compression so I swapped out the plugs in my 22 with my latest restorations. Took it out for a 5 mile spin and it ran great! Just wondering if anyone else runs restored originals in their car? The way I look at it I should never have to buy another spark plug!
Kind Regards
John
1922 Touring "Tinker"
1925 Roadster "Pops" (Pile Of Parts)
Martin, Ohio
Last Name: Hatch
Re: Take-Apart Spark plugs
Post by Dan Hatch » Sun Apr 28, 2024 6:29 pm
That is all I have ever used.
Last Name: Humble
Board Member Since: 2006
Post by Humblej » Sun Apr 28, 2024 6:31 pm
I run 100 year old Champion plugs but have never taken them apart to clean. I suspect the take apart feature was probably just necessary for production.
Will_Vanderburg
First Name: William
Last Name: Vanderburg
Post by Will_Vanderburg » Sun Apr 28, 2024 9:18 pm
I run original Champions in mine. I take all the ones I buy apart, clean them, make the electrode flat and gap them at 1/32nd of an inch.
William L Vanderburg
1922 Center Door Sedan
Post by Steve Jelf » Sun Apr 28, 2024 11:33 pm
Sure. Champion X (much cheaper than new), Splitdorf, and others. This page may be of interest to some:
https://dauntlessgeezer.com/DG95.html
Moxie26
Last Name: Jablonski
Post by Moxie26 » Mon Apr 29, 2024 6:12 am
Good old Edison number 14 's, gapped at 0.025".... Same set used the last 24 years.
Last Name: Humble
Post by Humblej » Mon Apr 29, 2024 6:45 am
My unrestored 1924 runs with its original to the car Ford script Champion plugs.
Post by Steve Jelf » Mon Apr 29, 2024 11:01 am
Jeff, that is certainly the right style of plug for 1924. But how do you know it has never been replaced?
Terry_007
First Name: Terry
Last Name: Bond
* REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1915 Chassis
Post by Terry_007 » Wed May 01, 2024 8:29 pm
Would enjoy seeing photos of some of the more interesting and unusual plugs in that load. I've been collecting them a long time and am always looking for one I don't have.
Thanks,
Terry
Last Name: Strange
Post by CudaMan » Thu May 02, 2024 8:47 am
I have a few Bethlehem "Five Point" spark plugs with four ground electrodes surrounding the single center electrode. The porcelains come in two styles, "fat" and "skinny". Both styles have 1/2 inch pipe threads. :)
