Looking for info on this head
Mike Penserini
Last Name: Penserini
* REQUIRED* Type and Year of Model Ts owned: 27 roadster pickup, brass speedster, Mercury # 253 B, Mercury # 1070, Faultless "Hoosier" parts collection.
Post by Mike Penserini » Mon Apr 29, 2024 12:43 am
Anyone have any info on this head ? Anyone else have one ?
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Re: Looking for info on this head
Post by Kevin Pharis » Mon Apr 29, 2024 9:54 am
If a fella couldn’t read… he would say that thing looks exactly like a Green Engineering flathead…!😳
Post by DanTreace » Mon Apr 29, 2024 10:18 am
Here's photo of the Green head.
The one by OP has metic spark thread holes, they aren't std Ford USPipe thread.
And Interesting round disc lump on top rear of the head and casting spots between cylinder for maybe drilling to add petcocks.
Erik Johnson
First Name: Erik
Last Name: Johnson
Post by Erik Johnson » Mon Apr 29, 2024 10:34 am
Courtesy of Google books - the only references I could find searching "turbo centaur marine" were in 1926 issues of "Power Boating".
T.C. Marine Motors 1.jpg (42.63 KiB) Viewed 2425 times
T.C. Marine Motors 2.jpg (37.16 KiB) Viewed 2425 times
David Greenlees
First Name: David
Last Name: Greenlees
* REQUIRED* Type and Year of Model Ts owned: 1915 Model T racing car, 1924 Model T Depot Hack with original York #803 body.
Post by David Greenlees » Mon Apr 29, 2024 11:59 am
I also found this add early this morning but didn't have time to post it then. After enlarging and editing it I see a Schebler air valve carburetor, an oil pump and lines, and a side-drive attachment for the ignition distributor.
John bevardos
Last Name: bevardos
* REQUIRED* Type and Year of Model Ts owned: Roadster, Coupe, pickup truck, 2-door
Post by John bevardos » Mon Apr 29, 2024 1:27 pm
Has anyone ever ran a green engineering head ? I would like to hear what their thoughts are. John
Who's still makes these gaskets, I might be in the market for a solid copper one myself.
Post by Mark Gregush » Mon Apr 29, 2024 9:19 pm
Wonder if the round bosses on it were to be drilled and tapped for a water manifold with the original one blocked off.
Post by Jerry VanOoteghem » Tue Apr 30, 2024 6:35 am
I think that's exactly it.
Post by Wayne Sheldon » Tue Apr 30, 2024 6:49 pm
This head is really intriguing! Since it states in the casting that it is "marine", I cannot help but wonder how the heads higher compression might affect performance. Most engine powered boats in those days were not high speed. Maybe the squish and flow area of the combustion dome was set for lower speed torque?
Regardless, if it were mine? I would want to put it on a known good running car and try it out to see how it would compare.
Another consideration of marine heads? Often they did not use a radiator mounted in the normal front location. Sometimes, they didn't use a radiator at all! Boats often ran water from the lake, river, or ocean water they sat in to keep the engine cool. Years ago, I saw a marine head that mounted onto a model T block with the radiator connection at the back of the engine. This one at least looks like it could be used on a model T car? I also feel that the large round embossment may have been for adding additional water routes if needed.
Interesting piece for sure!
Post by speedytinc » Tue Apr 30, 2024 6:58 pm
Take a volume reading of the combustion chamber. (CC's) & figure the compression ratio.
Notice it takes special, flat top pistons.
CamMan
Last Name: Young
* REQUIRED* Type and Year of Model Ts owned: '26 Tudor, '22 speedster, ABC/Rajo
Post by CamMan » Fri May 10, 2024 11:44 am
That head does not look at all like a Green head. The Green head did not have a squish style combustion chamber, see https://mtfctulsa.com/Tech/head_photos.htm. We attempted to run one on a dyno 20 years ago. The contour of the chamber caused the valves to get wedged with only a 280 cam. You would have to relieve that area to run one.
