Thanks for the ignition advice
Dave_Kriegel
Topic author - Posts: 74
- First Name: David
- Last Name: Kriegel
- * REQUIRED* Type and Year of Model Ts owned: 1927 1926
I just got a beat up 1921 with the ignition shot. I sent it out to the great ignition re-builder. To get the car running folks suggested running a 6 volt wire right to the coil box with an on off switch IT WORKS SO tomorrow try and start the car !
- Attachments
- volt.jpg (6.48 KiB) Viewed 2035 times
Re: Thanks for the ignition advice
If it has a generator don't forget to ground the output lead. Great good to hear.
